Apple Cinema Display to what?
harsaphes
Morning all. I read the display forum everyday and drool at the thought of a new monitor. Now mind you, I don't NEED a new display, my 30 inch ACD (original one) still works. But.....what would you go to if you were getting something new? It would have to be at least 30 inches since that's what I'm using now. Don't care about the cost, within reason of course.
I and my wallet await your thoughts.
ColorEdge CG318
Seriously. 100% srgb coverage with no oversaturation/undersaturation via 3d lut gamut transformation.
true 10bit 4096 x 2160 panel with 1500:1 contrast ratio and polarizer filter
16bit 3d lut
Color uniformity processing including backlight brightness correction.
Supposedly has great scaler and features for video signals since it's marketed as a grading display as well.
If I had the money I would buy this, It would last me 20 years until OLED displays with similar quality and functionality are on the market.
Lets take it down to 2000 and under, though that's a nice looking monitor it's totally overkill for me.
You could purchase virtually anything and it would be an upgrade over the old ACD. I recommend taking a peek through this forum post put together by [H]ard user NCX, and picking out something you fancy.
we can not give you meaningful advices without knowing your usage scenario.
Color critical work? The suggested Samsung U32D970Q looks great.
Gaming? The 27" Acer 1440p@120Hz.
Productivity? the Dell U2515H, especially in a triple portrait setup with 12 billion pixels.
A little bit of everything? A 34" 3440x1440 monitor with high refresh rate.
The caveats of each solution:
-32" 4k is too small for reading text at native resolution
-27" 1440p may feel like a downgrade in size and resolution
-40" 4k is so big that you may experience neck pain
- triple 25" 1440p is not is elegant as a single massive display
-34" with 100Hz refresh rate currently do not offer strobing backlight, hence they are not as good a gaming solution as the 27" 1440p.
if money is truly no object, there is one( and AFAIK only one) 32" 4k monitor capable of 1080p@120hz. NEC PA322UHD
Option: I need a little bit of everything, but not critical color work.
The U32D970Q uses a grainy, resolution negating (in terms of sharpness and clarity) matte coating and suffers from obvious overshoot ghosting regardless of which overdrive settings are used; it's an expensive joke, not a professional monitor.
The PA322UHD is awesome, but is very expensive and is really a monitor created for professionals who calibrate their monitors. The BenQ BL3201PH is currently the most rounded 32" 4k monitor, but it lacks Free-Sync unlike the Samsung U32E850R, but it uses the same grainy matte coating as their U32D970Q. Best Reviewed 32" 4k Monitors.
Then you are set on either the Acer XR341CK, which is a Freesync monitor that works well with AMD acrds, or the Acer XB270HU which is a gsync model that wroks with NVIDIA cards.
Assuming that AMD can produce and deliver a dual-gpu solution on the coming months, the 34" Freesync is currently the best all around monitor that money can buy, according to the results showed in this review. One day there will be a 34" gsync monitor on sale, but this day has not come yet.:(
The 27" gsync has a strobing backlight and an advantage when gaming, but it may feel like a downgrade from someone coming from a 30" 2560x1600, especially when not gaming.
