Apple 27" LED Cinema Display
I picked it up and it was new! Wow and it looks awesome! Got it hooked up to my MBP for the moment till my adapter comes in for my gaming rig. :)
Now I noticed the link in this thread to power off the monitor is no longer working. What do people do here to power off their monitors for the night? Since I don't turn my machine off but want the monitor off?
Brightness controller has an option to use a hotkey to turn off the display.
About iSight.
On my pc i get two seperate iSight devices when i connect the monitor.
One is the actual iSight device and it works just fine without any drivers. (win7/8 has drivers for it)
But the second iSight device shows up as "Unknown" in de device manager. Well that pissed me off good since none of the display or iSight related drivers from the bootcamp cd work.
Anyway after some digging i found the correct driver on the bootcamp cd.
The driver that matches the unknown iSight device is "Drivers\Apple\x64\AppleNullDriver64.exe"....
Why would Apple put in a device that is name iSight but does nothing and then name the driver NullDriver??? Well... It's Apple....
Okay, so how do I adjust the colors on this thing to work correctly in Windows 7? Looks great on my MBP but on my PC it's colors seem a bit off, maybe a bit dark too even when cranked up. Not sure what the deal is.
How much do you think I could get for a non thunderbolt display, mint condition.
I would assume $600-$700, more if it comes with the apple care warranty. I don't see any on craigslist to give you a good place to start and a lot of people seem to be buying the korean monitors for $400.
Guess this is too hard of a question to answer? LOL
Probably because the answer is pretty obvious
If you want to adjust colors manually - do it via the controls in the nVidia/AMD settings
If you want to adjust it automatically - buy a color calibrator
Seriously. As three4seven said, do your research and quit relying on everyone to hand feed you answers.
-How do I hook it up?
-How do I make it work?
-How do I turn it off?
-Brightness controller?
-How do I adjust the color?
Really? Did you read nothing in the thread?
Okay newbie how about you go somewhere else where you can be less rude and be more helpful.
See how many posts this thread has and pages? Yeah, it's a bit hard to find anything in this thread.
And most of the info in this thread is dated too so the reason I had to get it clarified.
Telling you to do your research isn't rude. It requires going back 5 pages with a bit of quick reading in between. Heck, the creator of Brightness control posted an update on THIS page.
And I wasn't asking about the Brightness controller. Guess you can't read. :rolleyes:
How is this monitor for PC Gaming ? I see it on sale on Craigslist for like $650.
Or other options are brand new Asus 27" @ $700, or the famous Dell U2711 for $800
What's the best monitor ? For those prices ?
The Dell ones can have very strong anti glare coating so make sure to see one in store. Do you like glass or do you like the the plastic sheen on your screen? Are you happy enough with the USB 2.0 ports? Do you want 16:9 or 16:10?
I love 16:9 it fits perfectly for YouTube 720 and 1080p, or PS2 emulation... I love the jet black border on this glass pane, it looks especially cool with vignette style UI like in Guild Wars 2. There is "IPS" sheen when the whole image is dark, but its more uniform than backlight bleeding. Choose your poison :)
Have you looked at the new Dell S series Zor? They are looking promising...
Thanks. Is that the new U13 model Anandtech reviewed recently ? Looks good.
I am not a fan of big anti glare screens, but also hate mirror finishes, I like something in between. But more important, I want the best colors, crisp/sharp image, good refresh rate for gaming.
My budget at $700 or so, is either the new Asus 27", or slightly used w/warranty Apple Cinema Display.
Have browsed through several pages of this thread.
I have a specific question. Sorry if it was addressed and I missed it.
Will the ACD work with Intel HD4000 onboard graphics with a standard Display Port output?
If so, what specific adapter cable would you recommend or can I use any female MDP to DP adapter?
Like this one?
http://www.amazon.com/StarTech-DP2MDPMF3-3-Feet-DisplayPort-Adapter/dp/B007580WGC/ref=sr_1_9?s=electronics&ie=UTF8&qid=1351003550&sr=1-9&keywords=DisplayPort+to+Mini+DisplayPort+Video+Cable+Adapter+-+M%2FF
Like this one?
Short answer to the bolded question: Yes. It should work just fine. This is of course assuming we're talking about the miniDisplayport version, and not the Thunderbolt version.
Not sure about that particular adapter - but I've used my ACD (miniDP version) with my Lenov X220 (which has a standard displayport) using a cheap adapter from ebay with no problems. The x220 has the HD3000 integrated graphics - so it should work fine for the HD4000 as well.
Thanks for the response.
My PC is in a basement rec room area with no big windows or a lot of light other than lamps.
The glossy screen should be fine.
Anyone looking to buy one of these should definitely wait for the update (whenever that is).. it seems they've been listening to those complaints about reflections with the new iMac display.
".. The new iMac also features a completely reengineered display that reduces reflection by 75 percent while maintaining brilliant color and contrast. In the new design, the cover glass is fully laminated to the LCD and an anti-reflective coating is applied using a high-precision plasma deposition process. Every iMac display is individually calibrated using an advanced spectroradiometer."
You said "update" I thought you meant something like a driver or flash to fix the existing models already out ? So that will be a whole brand new model for sale at high price ? Would it be Thunderbolt only, or also have the Display Port connection ?
No way I am spending the ca$h on a brand new Apple 27", those things are crazy expensive, especially a brand new model. If buying brand new, I will just go for the economical Asus 27" that is highly reviewed, or maybe for a little more a brand new Dell U2711.
I doubt they'll be a cinema display version if it though. Thunderbolt would be useless.
I have two of these guys now, just ordered #3.
Got a question regarding setting up 2d surround on these if anyone can shed some light.
Right now I have the two displays plugged into the leftmost card in a dual 670 sli config. One is connected with a mini DP to DP converter, the other one is going through an Atlona DP-400 to the top DVI port. I read through the documentation on setting up 2d surround, and it looks like I have a couple of options for where to plug in the 3rd monitor, either through the DP port on card #2 or to a DVI port using another of the Atlona converters, or going straight DVI meaning buying 2 more of the Atlona converter boxes.
Has anyone tried surround (nvidia) with these monitors? Do you think it will work with another mini DP to DP converter or will I need to get two more Atlona boxes and hook them all up with DVI?
Thanks in advance for any help, just getting into the surround game and I don't mind shelling out for a couple more converters, but would rather spend the money on beer and games.
When you get pics post them, I'm looking to add another 2 ACD. Also, how did you adjust the brightness? Did you do adjust them separately ?
Holst's control panel gives you a separate brightness slider for every display you plug in, as long as you attach the USB cable. You do adjust them separately, but it's not very hard to do.
Here is a screenshot of two screens I sent him for his site last night.
http://i.imgur.com/HE5dB.jpg
personally I would buy the korean ones if I were you guys. Especially as 2nd and 3rd ones since they are much cheaper and very similar. Just buy some nice monitor arms to put them all on and they would line up nice. I'd prob put up the extra cash and get a 120hz one, even though they have higher response time than the TN 120hz 1080p gaming monitors. If the korean 120hz monitors were avail at the time I bought my ACD, I prob would have got one of them instead in the first place. I love my ACD but higher hz at 1/2 the price is a great deal too. I'm almost considering selling my ACD and buying one, but I already own a very low response time 120hz + aggressive response time compensation 1080p TN that I dedicate to gaming. The 120hz korean 2560x1440 would have a little more blur/smear during FoV movement than the TN, it's RTC artifacts wouldn't disappear as fast, but its response time and blurring would be a lot better than an ACD in games, and its smoothness of motion tracking at the higher refresh rate. Since I dedicate my ACD to desktop/apps/imagery and my 120hz TN to gaming, its not a real necessity. The Korean monitor's color settings are also not as good as the ACD out of the box - I think you have to import some color profiles or something. There is also some slight risk, although the 120hz models are sold by a u.s. middle man I believe so may have better return policy/system.
Oh, the price I'm paying for these is less than the Korean ones as I'm getting them secondhand through work (I do IT at a graphics shop). Everyone's upgrading to Thunderbolt, so I'm snapping these up as they become available through our employee purchase program.
I don't want to say what I'm paying because I don't want to make anyone mad.
When you start up your ACD's can you see your BIOS? Or does it go blank until it enters windows?
On my GTX 580 I get no BIOS.
When I was just using the display port after I got my first one, I could see the bios.
After I plugged the other one in with a dp - dvi adapter I can't see it on either screen.
When I need to go to the BIOS I just disconnect DVI and it works fine.
I have the Atlona DP-400 to the top DVI and I don't get anything, must be the card.
What I was trying to get at, sorry if this was confusing, is that I can see and interact with the BIOS if I only hook up one screen to the display port on the first card in SLI, otherwise I dont see anything until I get to the login screen.
Anyway, who needs to interact with thier BIOS that often?
True, but I need to lug my older monitor down if I want to play around in my Bios, just a pain in the ass.
Don't know about using an adapter, but I used one of my displays directly into a miniDP on a 6970 and no issues seeing my BIOS.
