Liquid_Cooled
- Sep 28, 2004
Krycek1, my desk is an Ikea JONAS. Quality wise, its like any Ikea piece, veneer chips and scratches easily.
Can anyone confirm if the new Thunderbolt 27" Cinema display will still work with our Displayport / Mini-Displayport graphic cards for PC?
After about 1-2 months of owning this monitor compared to the U3011, I can honestly say i'm much more happier. The glossy screen is still somewhat annoying but it's much better then the AC of the U3011
Is it possible to connect two PC's at once on one ACD, if for example both PC's have a Radeon 6950 graphics card or one PC and one laptop by Apple?
If you're asking if the ACD27" supports a Picture By Picture mode, that isn't possible i.e. you can't display video side by side from two different PCs. Atlona does, however, sell miniDisplayPort KVM switches that support 2560x1440. I have my ACD27" hooked up to both a PC and a Playstation 3, and I toggle between the two with a single button press.
How does the glossiness of the ACD compare, in real world use, to the glossiness of the screen on MBPs?
Awesome setup btw, keyboard from 80s acompanied by 2011 monitorsAfter about 1-2 months of owning this monitor compared to the U3011, I can honestly say i'm much more happier. The glossy screen is still somewhat annoying but it's much better then the AC of the U3011
Hey Guys.
I am about to throw this screen in the bin.
I purchased the 27" LED Mini DP screen last week and it works on my macbook.
My Pc on the other hand.. I have the
Asus GTX580 Direct CUII. Plugged into
> Male Display Port/Male Display Port
> Female Display Port/Male MiniDisplay Port
> Female Mini Display Port/Female Mini Display Port
> ACD Male Mini Display Port.
I have the latest nvidia drivers. I connect the display plug in usb turn on computer.
Nothing.
No change in the display at all.
I connect a secondary display to DVI and in the nvidia control panel it says Apple LED Display.
But i cannot click it or select it.
WHAT IS GOING ONi spent 8 hours last night trying to work it out. Is it my cables? or my GPU? it doesnt post Bios AT all.. it must be hardware?
Please support me, anyone... im ready to return the most beautiful display and forget ever using apple again.
It's probably all the displayport converters you have. Just get a simple Displayport Male to MiniDP female. Should work fine.
So - therefore it has something to do with the cabling/power. It's possible there is too much interference with so many adapters. It's a $10 cable. It's worth a try.
Leaves two options.
The adapter is dead.
Or the screen does not allow the use of more than one cable/adapter.
Hi ProficienT,
One question, why do you need 2 cables in your setup? A single "Mini Displayport Female to Displayport Male Adapter Cable" should allow you connect the ACD27" directly to your GTX580, no? And I don't know why the number of adapters would matter. I did a wild daisy chain across DVI and VGA to hook up my ACD27" to my VGA XBOX360 and it worked.
So is there 100% certainty that the Thunderbolt display will work only with Thunderbolt ports and not existing mini-display ports?
Yeah... a lot of guys over at MacRumors have gotten their Thunderbolt displays and it's 100% confirmed. Right now, Thunderbolt display + anything that doesn't have a Thunderbolt port = Not possible.
I actually found a better way to get the AppleControlPanel for Brightness to work in Windows 7.
#1) Right Click on "Computer" -> Select "Manage" and in the users area create a user account called: Test (with password: Test) -> Not an admin account!
#2) You have to create a shortcut to the EXE itself, and in the shortcut box change the part that points to the EXE itself (Not the 'Start In" area) Change to: "C:\Windows\System32\runas.exe /user:test C:\AppleControlPanel.exe" (Or whatever/whereever your ControlPanel filename is...If shortcut is in the same folder as Exe you do not need to enter a harddisk or filepath before AppleControlPanel.exe)
Before creating shortcut like this I was getting the Startup Error every time I tried to control brightness, And there was no way I was going to depreciate my Win7 install with unneeded bootcamp pollution. BTW: My disk drives run in AHCI mode and theres no chance I'll be changing that to IDE to make something run right![]()
Beware what brand you buy. Powercolor 6970s wouldn't work with my ACD whereas XFX did.
since powercolor 6970 didn't work with the 27 inch ACD, do you think this will have the same issue with a powercolor 6990? anybody tried this?
Wow, that sucks. I was under the impression that all Radeon 6xxx cards were ACD27" compatible. Wouldn't the miniDP inputs be electrically identical regardless of the vendor? Anyone else have any insight on this?
Maybe it's a weird powercolor thing.. my MSI 6970 works fine with my 27" ACD..
