- Oct 29, 2000
Hey all,
Just received my SUA1500 with AP9617 network management card used from eBay.
Bought and popped a new battery in it, and I am ready to set it up.
Problem is the APC device IP configuration utility does not find it on my network.
I pulled the mac address off of my managed switch for the port it is plugged into, to see if I could find an IP in my routers ARP tables, but no such luck. The MAC isn't in the ARP tables.
My guess is that it is not using DHCP, but is configured to a static IP on a different subnet by the previous user.
I've tried pressing (and holding) the reset button on the back of the back of the network management card, but this does not appear to help.
Does anyone have any ideas on how to solve this?
Much appreciated,
Matt
Much appreciated,
Matt
