Anyway to restore appdata/local folder?
MissJ84
Hi, a friend of mine deleted the local folder by accident. Its on an ssd, and obviously the recycling bin is disabled. Any kind of programs out there that can restore the lost data? Thanks!
Well, my first suggestion would be to make an immediate image of the drive so you can always go back in case recovery goes sideways. Once you have made the copy, use something like GetDataBack www.runtime.org or some other recovery utility and see what it can restore. Once that is done, suggest to your friend that he purchase an external drive and make frequent backups!
Right click the AppData folder and go to the previous versions tab?
