So here it is, if I left out any important details I'm sure you guys will find it and ask
1) What will you be doing with this PC?
All the general stuff like web surfing, email, MS office etc. But the main focus will be on Photohop, a little bit with Premier, and some web dev. But Photoshop is the #1. Gaming is also of interest but isn't the top priority, not much time for games these days.
Started with a $1000 goal with hopes that it would stay under $1500. Right now I'm in the mid $1200's range without an OS, so I'm fairly on target and I'd like to keep the hardware right around the $1200 I'm at now.
3) Where do you live?
Washington state
4) What exact parts do you need for that budget?
Everything except the parts listed below that are being reused.
5) If reusing any parts, what parts will you be reusing?
Dell 19" analog LCD (non-widescreen), keyboard, mouse, speakers and all my existing network equip. The monitor will be a near future upgrade, but ATM it's going to have to do.
6) Will you be overclocking?
Probably not, I don't want to completely rule it out, but it's not too important, if it OC's decently then I'm happy, I don't need to have it cranked way up.
7) What size monitor do you have or plan to have?
19" 4:3 Dell. Will be upgraded sometime soon
As soon as I get everything figured out.
9) What features do you need in a motherboard?
RAID would be the one thing that I would really like to keep as an option, I'm borderline thinking of adding another drive to this build and doing a mirroring setup.
10) Do you already have a legit and reusable/transferable OS key/license?
The OS is my sticking point, I can't decide if I want XP 64 or if I should just get Vista 64. All my past experiences with Vista have ended in frusteration. My thought is that if I'm going to be frusterated and have to fiddle around with an OS I might as well just install the Windows 7 beta and not have to pay for something that I have to tinker with. Has Vista come along enough to be worth my money?
Here's the Hardware list, first a link to a Newegg wishlist if that's easier...
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=10653106
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory Model F3-10600CL9D-4GBPK - Retail
Antec Signature SG850 850W ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply - Retail
SAPPHIRE 100259-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
LG 22X DVD±R DVD Burner Black SATA Model GH22NS30 - OEM
Intel Core 2 Quad Q9550 Yorkfield 2.83GHz LGA 775 95W Quad-Core Processor Model BX80569Q9550 - Retail
GIGABYTE GA-EP45T-UD3LR LGA 775 Intel P45 ATX Intel Motherboard - Retail
SAMSUNG Spinpoint F1 HD103UJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
NZXT HUSH Black SECC Steel/ Aluminum/ Plastic ATX Mid Tower Computer Case - Retail
I chose a case that says it's made to be extra quiet which I would appreciate, but I don't want to build a system that's going to run hot because I insulated it with noise dampening material which this case comes with.
I was originally going to build an i7 based system but it seems like it just costs too much more based on what I tried to put together, but if you guys can come up with a solution that will put me in the same horsepower range with an i7 I'm certainly open to that as well.
Washington state
