After being frustrated at room temp water cooling solutions I've upgraded to a chilled water/antifreeze (55F) running to both my P4 3.4 (OC 4.0GHz) and X800 XT PE (526MHz)... I'm wondering if anyone else has done this?
I'm using 3/4in hoses which split to 3/8 and 1/4 in for the CPU and GPU respectively. The Chiller is a 1/3HP model with 40F maximum chilling capacity and the Pump is a 350GPH marine aquarium pump with Micron filter. Total cost is estimated at $600-700 to cool a $300 CPU and $500 GPU.
CPU is normally at 66-68F (coolant is 55-58F) and GPU is 62F
Under load CPU shoots to 80F and GPU to 76F
I'll try to include photos either as in-line or links...
Gene
Gene
