houkouonchi
RIP
- Sep 14, 2008
Is it really unlimited? I am guessing its not gonna go through but I am currently in the process of uploading 10+TB to them. What should I expect?
How long would it take you to re-download 10TB of data in the case of a loss? Wouldn't it be better to find some other, more responsive, backup solution? That's seems like a heck of a lot of data for online backup.
I've been thinking about buying a subscription, but it would take forever to upload with my connection, and I have a 250GB bandwidth cap.
They have an option where they will ship you a 1TB hard drive and then you ship it back to them and they copy it to their server.
I need to backup about 4TB though.
dataTo the people that put TB's on crashplan..what are you putting up there?
I am thinking about using Crashplan also, and i will likely upload photo, and some old document files and data. hmmm.
The 4+ month it takes to upload the data doesn't sit too well with me.
I do have one complaint with Crashplan. There client is a memory hog. On my Win7 machine it usually sits at about 450MB of memory even when it is not backing up. Not exactly a light client.
Anyone else experience this?
http://support.crashplan.com/doku.php/faq/securityWas actually just looking over some remote backup options just in case the external backups in the fireproof safe are lost.
My only question is that, uploading to a service such as CrashPlan, what about security? Wasn't it Google's own data warehouse that said once you upload your documents, pictures etc, they can do with it as they please and use it without your permission?
Anyone know of the type of security with CrashPlan or is it just a 'whatever' approach with security?
I used crashplan for about a year, possibly a bit longer to backup my desktop to a NAS. I stopped using it is due to their restore process, it really is abysmal. The only time i ever use restore is after a format or on a new machine, when you install crashplan it gives you an option to adopt the old machine, if you do this it DELETES all of your backup files. I did this once and only a zfs snapshot saved me.
If you do manage to import an old backup you have to restore all of the files somewhere temporarily, or hope you chose all the files you needed restored and didn't forget something because they force you to delete the entire backup archive before continuing with a new backup! (This is the only backup software i've ever seen do this) You can never just leave that old backup alone so you can go back and grab files later if something was forgotten. Anyone who has crashplan installed on windows 7, check your event viewer for administrative event's, i've had tons of strange windows logon service issues as well as a few other errors related to crashplan that seem impossible to resolve (VSS). Also, it will happily use 400MB+ of ram. Unfortunately i haven't found any stable, viable alternatives so i'm stuck using the standard windows 7 backup for now. Acronis looks promising but the 214MB installer is keep me afraid for now, i'm sick of backup software compromising the stability of my system.
This is NOT true AT ALL.
When you adopt a computer (great for reinstalls), it will do a resync which may look like it removes all your files...but it doesnt. It will resync 50gb in a couple minutes. The trick is DO NOT change your file locations. Then it WILL delete as it warns you.
Havn't tried any restore yet, but I have my windows-clients backup both to the CrashPlan-servers and to my OpenIndiana-server, so that if my windows-client needs restore I can do that locally, and in worst case scenario its still backed up to the cloud anyways.
Are you also backing up your windows machines to the cloud? Or just to your OpenIndiana-server. If you are only backing up locally they are not backed up to the cloud. One thing I hate about the software. It excludes all crashplan backup files.
