anyone use
fatdog said:
the Proview monitors?
http://www.walmart.com/catalog/prod...7802&type=19&dept=3944&path=0:3944:3951:37802
not a bad price,just wonder how the quality is.may pick one up just to see.
Look around. There are a few 19WS out there that are probably better than Proview including one from Viewsonic going for about the same price.
Also consider the vertical height on a 19" WS is fairly short, less tha 1000 pixels. Also they use an odd native resolution. OK if you just want it for desktop use.
For like $50 more you get a 20" WS Sceptre from Costco which many people seem to be saying is decent for the low price.
Sceptre
Edit: It's actually $319 after rebate so a little more than $50 bucks more. But it has a DVI connector which the Proview doesn't.
thanks.
i am really looking at the viewsonic 19 widescreen or just a plain 19"
