Anyone use HDMI/DVI switches?
Daggah
So I ordered a PS3, but right now I don't have room for a nice big HDTV, so I'll be using it on my Dell 2407WFP. I have an XBOX 360 hooked up to the VGA, my PS2 hooked up to the component (and of course I acknowledge that the component inputs on the 2407 aren't very good) and of course my PC hooked up via DVI. I'd like to hook the PS3 up via HDMI->DVI, and I was looking at the HDMI switches on monoprice.com (example, 2 port HDMI switch). It says that the switch is HDCP compliant. It also says the maximum resolution is 1080p.
So, if I do an HDMI cable from the PS3 to the switch, a DVI to HDMI cable from my PC to the switch, and then an HDMI to DVI cable (I assume the HDMI-DVI cables are interchangeable) to my monitor, my questions are:
1) Will I lose any noticeable image quality?
2) Will I lose out on 1920x1200?
These things seem pretty reasonable for $20-$40 (depending on how many HDMI ports you get) so I'm wondering if it's "too good to be true." For whatever reason, a DVI switch from their site with the same number of ports range from $35 and up, are advertised as having a max resolution of 1600x1200, and don't say whether they're HDCP compliant.
If the display supports 1920x1200 over HDMI/DVI, I don't see an issue with that. I don't think you will lose out on image quality or see a rise in input lag either.
I have used an HDMI switch with both BenQ and Westinghouse monitors without issue. The only problem I've ever seen is some red snow from ATI 38x0 cards when connected over port 2 of the video card (the port closest to the motherboard.)
Regards,
10e
