Anyone spot a single slot 750 ti yet?
Discussion in 'Small Form Factor Systems' started by 1_legged_sheep, Feb 26, 2014.
  1. 1_legged_sheep
    1_legged_sheep Limp Gawd
    397
    Apr 20, 2010
    The 750 ti review card that nVidia sent to all the review sites was a single slot (with a cooler that stuck out a bit). It looks as if no manufacturers actually used this design :( All the 750 ti cards I can find are double slot.. Has anyone spotted a single slot out in the wild yet?
  2. nuttcase21
    nuttcase21 [H]Lite
    127
    Mar 3, 2012
    nothing I've seen yet but I'm waiting for one myself. have 2 on the way already and they're both double slot.
  3. sgtspiff
    sgtspiff Limp Gawd
    137
    Jan 14, 2011
    Apperantly is the cooler fittings on the 750/750ti 43x43mm which is very uncommon. Hence the 3rd part producers couldn't use existing fans and heatsinks from other cards.
    So we'll see which of them that will be ready to produce new passive and single slot coolers.
  4. SithSolo1
    SithSolo1 [H]ard|Gawd
    1,205
    May 24, 2001
    Didn't the same thing happen with the 650 series? The reference card was almost single slot but none of the manufacturers really went with the design.
  5. trizc
    trizc n00b
    49
    Oct 17, 2011
    anyway to replace the backplate universally and get a low profile fan?
  6. AFD
    AFD 2[H]4U
    2,154
    Aug 7, 2013
  7. cortexodus
    cortexodus [H]ard|Gawd
    1,614
    Feb 20, 2009
  8. Zero Cool
    Zero Cool Limp Gawd
    136
    Feb 28, 2014
  9. Zero Cool
    Zero Cool Limp Gawd
    136
    Feb 28, 2014
    Same with this one, looks like a single slot until you set it on its back haha.
    [​IMG]
  10. AFD
    AFD 2[H]4U
    2,154
    Aug 7, 2013
    Oops! Well it's a single-slot bracket.. just swap out the cooler :D
  11. milkcow
    milkcow Limp Gawd
    352
    Jul 8, 2013
  12. milkcow
    milkcow Limp Gawd
    352
    Jul 8, 2013
    The Nvidia card isn't really a single slot card either ...
    [​IMG]
  13. sgtspiff
    sgtspiff Limp Gawd
    137
    Jan 14, 2011
    It's a bit strange the situation right now.
    KFA/Galaxy has already made a nonstandard card with the low profile one. Almost all the others has made cards with nonstandard PCB to use there own coolers.
    So if there would come passive or single slots in the first wave then they should've been released.
    I'm I not correct?
    So if they would produce something more it would be in the second wave of releases. But when does those turn up usually? 1 month? 6 months? a year?
  14. updawg
    updawg Gawd
    608
    Mar 20, 2010
    Low profile dual slot cards are perfect too. Especially when loneindustries creates his L2 case.
  15. Zap
    Zap [H]ard|Gawd
    1,421
    Apr 1, 2004
    Passive would require a big heatsink. Now, LP single slot should be doable. Heck, I have a Sapphire Radeon HD 7750 that is LP single slot. It is the 800MHz version chip, which has a TDP of 55W. That's the same TDP as a GeForce GTX 750 (non-Ti). I'd love a LP single slot GTX 750, as that would give me maybe 60% more performance in my ISK 300-150 LAN box which has since been upgraded to a Core i5-4670K and (already have, soon to be installed) Radeon 7750. A GTX 750 would be awesome for it!
  16. SRTie4k
    SRTie4k Gawd
    959
    May 22, 2008
    I would still be happy with a single slot bracket but a double slot cooler, but there aren't even any of those available in the US. Only one in the 750 line available is the Asus GTX 750, but I want a Ti with 2GB.
  17. Unknown-One
    Unknown-One [H]ardForum Junkie
    8,870
    Mar 5, 2005
    Surprised nobody has built a GTX 760 style cooler for this thing to get it down to a single-slot. Something like that would allow for a single-slot heatsink covering the entire face of the card + a slim blower fan hanging off the end.
    It would probably end up looking like an 8800GT (with less PCB):
    [​IMG]
    The 8800GT was a 105w TDP card, so a heatsink that size should have no trouble with a 60w card like the GTX 750 Ti.
  18. Zap
    Zap [H]ard|Gawd
    1,421
    Apr 1, 2004
    The problem with the 8800GT cooler was noise. People these days are less tolerant of that.
  19. sgtspiff
    sgtspiff Limp Gawd
    137
    Jan 14, 2011
    Ok now I'm getting worried.
    Still only KFA2/Galaxy that has made a card that's not "standard size with own fan" card.
    On paper the 750/ti is perfect for passive cooling. Why havn't they realised it yet?
    To soon?
  20. cennis
    cennis Limp Gawd
    375
    Aug 15, 2013
    passive cooling has already been demonstated to work, just need some manufacutre to realize the market for it
  21. reukiodo
    reukiodo n00b
    1
    Jun 1, 2014
  22. WiSK
    WiSK 2[H]4U
    2,207
    Oct 28, 2011
    Nice find Reukiodo! :D
  23. andgo
    andgo [H]Lite
    99
    May 15, 2014
    Now we just need a single slot low profile, lol.
    By the way, Zotac also made a gtx 750 that's almost identical to the KFA2/Galaxy card.
  24. Geoffrey4283
    Geoffrey4283 [H]Lite
    84
    Aug 22, 2005
  25. sgtspiff
    sgtspiff Limp Gawd
    137
    Jan 14, 2011
    Now it's only the passive version that is missing.
  26. Unknown-One
    8,870
    Mar 5, 2005
    It's worth mentioning that the GTX 750 and GTX 750 Ti use exactly the same heatsink mount-points as a GeForce 6600GT
    Any heatsink that fits a 6600GT will fit these cards... including the Nvidia reference heatsink (which is a small single-slot cooler)
    [​IMG]
    Anyone want to attempt a transplant? :D
  27. WiSK
    WiSK 2[H]4U
    2,207
    Oct 28, 2011
    Also worth mentioning that many 750Ti implementations use a 4-pin micro PWM header for the fan, so make sure you can recrimp or solder the correct connector.
  28. Unknown-One
    8,870
    Mar 5, 2005
    Huh, weird. Every 750 Ti I've seen so far has a basic 2-pin fan header.
  29. tetrismaster
    tetrismaster [H]Lite
    77
    May 21, 2012
  30. Juan Carlo
    Juan Carlo n00b
    20
    Jul 6, 2013
  31. AFD
    AFD 2[H]4U
    2,154
    Aug 7, 2013
  32. SaperPL
    SaperPL [H]ard|Gawd
    1,807
    Aug 31, 2014
    I've got Gainward 750 with 2GB, not TI thou - works well :)
    And yeah, its pure single slot. Any questions?
  33. cortexodus
    1,614
    Feb 20, 2009
    Where can I purchase an actual single slot 750 or 750Ti in the US?
  34. SaperPL
    SaperPL [H]ard|Gawd
    1,807
    Aug 31, 2014
    I got it from german distribution in europe, sorry
  35. SithSolo1
    1,205
    May 24, 2001
    Most of the neato cooler designs don't make it over here unless you get them through ebay.
  36. cortexodus
    1,614
    Feb 20, 2009
    That reminds of the Zotac 670 Twincooler. I think it was only around in Japan. It's really irritating that there are no single slot 750's or 750Ti's readily available in the US. I'm not about to pay $100 premium to import one.
