Riptide_NVN
- Mar 1, 2005
I've seen posts about ghosting issues over the component ins. Are you using the DVI and getting that effect? If so perhaps it is defective. That is a bummer.
kaldaim said:Well, it appears that my Westy IS actually a dud.
Based on my ghosting and dead pixel problem, I was going to take it back to Best Buy.
A friend was going to help me take it back tomorrow, and I've been using it the past few days as a TV trying to decide if I wanted to buy another large screen HDTV.
Earlier today I went to turn it on and it wouldn't work. So I unplugged it, plugged it back in, and it worked fine. Just now I was using it to watch a TV show and it shut off. Now it won't turn back on at all.
It is likely my problems were just because of it being a bad unit, so if you were taking the ghosting problems I had into consideration I guess you can dismiss them.
Deutch420 said:SUXX
Do not dismiss a exchange for a new unit.. I really like mine, and i dont think you should give up on Westinghouse until you see it to its potential...
H-street said:for the price it is well worth it.. time for the 2005FPW to go in the garbage
rayman2k2 said:I think you should dismiss before it breaks after the return period is up.
Deutch420 said:jealousy
rayman2k2 said:i'm good with my 61" 1920x1080 Samsung DLP
besides like a previous poster pointed out, who said my computer could handle it?
H-street said:Ok here are some pictures.. i set my backlight at 30 and then ran through the Nvidia display calibration utility and i am very pleased with the color and brightness now..
the final settings on the TV are
Brightness 47
Contrast 50
Saturation 50
Hue 0
Backlight 30
here are some pictures , these are large res so 56kers beware (400k / picture)
Here are some on the on Desk, for scale the blue verticle ruler is 6" and the silver ruler on the desk is 12"
some are with or without the flash
http://www.fifthelement.net/images/W37/000_0016.jpg
http://www.fifthelement.net/images/W37/000_0018.jpg
http://www.fifthelement.net/images/W37/000_0019.jpg
This is the text close up, forgive me but my hands are not that steady..
http://www.fifthelement.net/images/W37/000_0023.jpg
Eve-online, its in windowed mode so you can see the title bar at the top
http://www.fifthelement.net/images/W37/000_0025.jpg
The new Empire at War Demo (loving this game).
http://www.fifthelement.net/images/W37/000_0003_00.jpg
http://www.fifthelement.net/images/W37/000_0004_00.jpg
http://www.fifthelement.net/images/W37/000_0007_00.jpg
http://www.fifthelement.net/images/W37/000_0009.jpg
and COD2, this shot turned out dark because of the dark level i am in, if you want more i'll post more.
http://www.fifthelement.net/images/W37/000_0026.jpg
Also i have found no dead pixels so far ..
here is the backlight test, i usually don't run these just because for me as long as it looks good and plays well i don't go "looking" for problems but someone might be interested, this is lights turned off with no flash.
Backlight 100%
http://www.fifthelement.net/images/W37/000_0006.jpg
Backlight 30% (my setting)
http://www.fifthelement.net/images/W37/000_0007.jpg
Backlight 0%
http://www.fifthelement.net/images/W37/000_0004.jpg
After a day of COD2 i can honestly say i didn't notice any ghosting during normal play, it seemed to play identical to my 2005FPW as far as quality of movement , but IMHO this monitor has better colors over my Dell
-- edit fixed the backlight 30% image link
S1N3R6Y said:Ordered a refurbished one from westinghouse.com for $1577.03 total in California. Ordered it friday and they shipped it same day. Expecting it on monday.
Rhinohelix said:You know, I thought I had no ghosting, either, but whether it has just started or I just noticed it, my blacks do ghost a slight bit. I noticed it playing the new Raindow 6:Lockdown demo. Just the blacks, no other color ghosts at all, that I can see. The blacks do leave a trail in most cases, just slightly. Damn. I may have to try my luck with an exchange, as I don't want to regret that after my 30 days are up.
Also, I ordered a dual-link DVI cable, to replace the one I was using from my 2005fp. I have read several people getting better IQ by using either a dual link or one from a 2405fp.
Rhino
Rhino
morfinx said:I had been using the DVI cable that my 2005FPW came with til I got my dual-link DVI cable. I don't really have time to game much nowadays, but there were no noticeable image quality differences just from normal 2D usage. Honestly dual-link cable isn't really required, but it just looks damn cool being twice the diameter of the single link cable
Tanquen said:A dual-link DVI cable will have an extra group of pins in the middle that a non dual-link cable wont have. They are both part of the same DVI standard. If a device needs more bandwidth the product manufacture can get it buy stepping up to dual-link DVI. If you look at the DVI connection on the display it will or should have all the pin holes for both and the blade if the display uses dual-link or not. Most cables that are around thus far will only have the single-link set of pins with the blade. You can use a dual-link cable on a display that is not dual-link capable but the extra pins are just ignored.
ben johnson said:I have $1500 ready to spend on a monitor. What would be the best monitor for this money?
I have seriously been considering the Samsun 244T or the Westinghouse 37".
What would you do?
Thanks for your help.
Huggles said:Hehe I wouldn't know, never used it as a TV yet....
Need to take more pictures, but I left my 20D's battery charger at my last photoshoot...
