Anybody using an AMD OPTY or X2
cabanaboy38
I am tryin to build a SFF system. I have the case X-Qpack. I am wondering which motherboard you are using I know there are not very many
I believe alot of people are using the BIOSTAR TForce6100-939 but according to Aspire's site, the Q-Pack can support any MicroATX motherboard. You can specify that on a Newegg motherboard search to see what should work in your future rig.
I have an opteron 170 on an ASUS A8N-VM CSM (t-force 6150/430) with 2gb of PQI Turbo ram and a hitachi SATA II HD, and have had no problems at all, and it runs like a gang-raped ape :)
If you want to overclock, use Biostar 6100 or Foxconn 6150. If not Asus 6150 or MSI 6150 has more features.
If you're getting an Opteron, by all mean OC it!!
X2 4400/ MSI K8NGM2-FID here. After the obligatory reinstall of XP everyting is working silky smooth here. :cool:
opteron 148@2800 asrock s56 board x800gto2 @560/610 but origional psu not the best
see sig.
Currently OC'd to 265x10 @ 1.35 or 1.375 vcore I forget ATM, i'm at work. but i'm going to be working on the OC tonight.
X2 3800 in a Shuttle SN25P.
Running at 2.5Ghz for a while now. Pretty stable once I *FOLLOWED* the SN25 Setup Guide.
It's picky bout it's drivers in my experience....
HTH
