I'm just getting into folding and now for the first time since my 2500+ Barton I feel the need to get my processor overclocked as high as possible. I have 5 feet or so of .003" x 1" high purity indium foil from other projects to play with but my initial tests on my E8500 are far from impressive. On the barton core, since there was no IHS and the core was quite small, it wasn't very difficult to get a high enough PSI on the interface for it to beat a proper application of normal thermal compound.
For the LGA775 on the other hand, the contact area of the IHS is 28x28mm, and from an Intel spec sheet I found a maximum recommended mounting force of 311 newtons. Some quick math and that only gives ~57.5 psi, which is about 1/3 of what I would ideally want. Has anybody experimented with (much) higher mounting forces? Is the 311 newtons the limit before cracking the die, or the limit due to the 4-hole WTF were they thinking motherboard mount? Can I exceed the limit if I properly reinforce the back of the motherboard?
Also indium has a melting point of around 155C, anybody know what will happen if I heat up the heat sink to 160C with it mounted to the (unplugged) CPU/motherboard? It would only be for a little while
