anybody running Linux flavor?
FlyBy
Hey Guys,
Is anybody running a linux ditro on your machine ? Can you please give me the details about your configuration?
Thanks in advance.
Since early 2000s I have run gentoo at home and at work (several dozen machines real + virtual 100TB+ of storage). In 2005 I switched to x64 with the migration to Athlon64.
Details hmm too many machines to list..
My home p5q-pro based HTPC which has been running almost 24/7 since I installed it in December of 2008 this was an upgrade from the previous HTPC dual processor dual core Opteron system.
Code:
jmd0 work # uname -a
Linux jmd0.comcast.net 3.12.17-jmd0-zfs-9999-2 #3 SMP PREEMPT Tue Apr 15 00:21:09 EDT 2014 x86_64 Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz GenuineIntel GNU/Linux
jmd0 work # lspci -v
00:00.0 Host bridge: Intel Corporation 4 Series Chipset DRAM Controller (rev 03)
        Subsystem: ASUSTeK Computer Inc. P5Q Deluxe Motherboard
        Flags: bus master, fast devsel, latency 0
        Capabilities: [e0] Vendor Specific Information: Len=0c <?>
00:01.0 PCI bridge: Intel Corporation 4 Series Chipset PCI Express Root Port (rev 03) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
        I/O behind bridge: 0000c000-0000cfff
        Memory behind bridge: fd000000-fe7fffff
        Prefetchable memory behind bridge: 00000000d6000000-00000000dfffffff
        Capabilities: [88] Subsystem: ASUSTeK Computer Inc. P5Q Deluxe Motherboard
        Capabilities: [80] Power Management version 3
        Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
        Capabilities: [a0] Express Root Port (Slot+), MSI 00
        Capabilities: [100] Virtual Channel
        Capabilities: [140] Root Complex Link
        Kernel driver in use: pcieport
        Kernel modules: shpchp
00:1a.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #4 (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 16
        I/O ports at b800 [size=32]
        Capabilities: [50] Vendor Specific Information: Len=06 <?>
        Kernel driver in use: uhci_hcd
        Kernel modules: uhci_hcd
00:1a.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #5 (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 21
        I/O ports at b880 [size=32]
00:1a.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #6 (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 18
        I/O ports at bc00 [size=32]
00:1a.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #2 (prog-if 20 [EHCI])
        Memory at fcfffc00 (32-bit, non-prefetchable) [size=1K]
        Capabilities: [50] Power Management version 2
        Capabilities: [58] Debug port: BAR=1 offset=00a0
        Capabilities: [98] Vendor Specific Information: Len=06 <?>
        Kernel driver in use: ehci-pci
        Kernel modules: ehci_pci
00:1b.0 Audio device: Intel Corporation 82801JI (ICH10 Family) HD Audio Controller
        Subsystem: ASUSTeK Computer Inc. Device 82fe
        Flags: bus master, fast devsel, latency 0, IRQ 46
        Memory at fcff8000 (64-bit, non-prefetchable) [size=16K]
        Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
        Capabilities: [130] Root Complex Link
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 1 (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
        I/O behind bridge: 00001000-00001fff
        Memory behind bridge: fea00000-feafffff
        Prefetchable memory behind bridge: 00000000d0000000-00000000d01fffff
        Capabilities: [40] Express Root Port (Slot+), MSI 00
        Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
        Capabilities: [90] Subsystem: ASUSTeK Computer Inc. P5Q Deluxe Motherboard
        Capabilities: [a0] Power Management version 2
        Capabilities: [180] Root Complex Link
00:1c.4 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 5 (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
        I/O behind bridge: 0000e000-0000efff
        Memory behind bridge: fe900000-fe9fffff
        Prefetchable memory behind bridge: 00000000d0200000-00000000d03fffff
        Capabilities: [90] Subsystem: ASUSTeK Computer Inc. Device 82d4
00:1c.5 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 6 (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
        I/O behind bridge: 0000d000-0000dfff
        Memory behind bridge: fe800000-fe8fffff
        Prefetchable memory behind bridge: 00000000d0400000-00000000d05fffff
00:1d.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #1 (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 23
        I/O ports at b080 [size=32]
00:1d.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #2 (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 19
        I/O ports at b400 [size=32]
00:1d.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #3 (prog-if 00 [UHCI])
        I/O ports at b480 [size=32]
00:1d.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #1 (prog-if 20 [EHCI])
        Memory at fcfff800 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 90) (prog-if 01 [Subtractive decode])
        Bus: primary=00, secondary=05, subordinate=06, sec-latency=32
        Memory behind bridge: feb00000-febfffff
        Prefetchable memory behind bridge: 00000000f4000000-00000000fbffffff
        Capabilities: [50] Subsystem: ASUSTeK Computer Inc. Device 82d4
00:1f.0 ISA bridge: Intel Corporation 82801JIR (ICH10R) LPC Interface Controller
        Kernel driver in use: lpc_ich
        Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 82801JI (ICH10 Family) SATA AHCI Controller (prog-if 01 [AHCI 1.0])
        Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 45
        I/O ports at ac00 [size=8]
        I/O ports at a880 [size=4]
        I/O ports at a800 [size=8]
        I/O ports at a480 [size=4]
        I/O ports at a400 [size=32]
        Memory at fcffe800 (32-bit, non-prefetchable) [size=2K]
        Capabilities: [80] MSI: Enable+ Count=1/16 Maskable- 64bit-
        Capabilities: [70] Power Management version 3
        Capabilities: [a8] SATA HBA v1.0
        Capabilities: [b0] Vendor Specific Information: Len=06 <?>
        Kernel driver in use: ahci
        Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation 82801JI (ICH10 Family) SMBus Controller
        Flags: medium devsel, IRQ 18
        Memory at fcfff400 (64-bit, non-prefetchable) [size=256]
        I/O ports at 0400 [size=32]
        Kernel modules: i2c_i801
01:00.0 VGA compatible controller: NVIDIA Corporation GF119 [GeForce GT 520] (rev a1) (prog-if 00 [VGA controller])
        Subsystem: ASUSTeK Computer Inc. Device 83bd
        Flags: bus master, fast devsel, latency 0, IRQ 47
        Memory at fd000000 (32-bit, non-prefetchable) [size=16M]
        Memory at d8000000 (64-bit, prefetchable) [size=128M]
        Memory at d6000000 (64-bit, prefetchable) [size=32M]
        I/O ports at cc00 [size=128]
        [virtual] Expansion ROM at fe700000 [disabled] [size=512K]
        Capabilities: [60] Power Management version 3
        Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [78] Express Endpoint, MSI 00
        Capabilities: [b4] Vendor Specific Information: Len=14 <?>
        Capabilities: [128] Power Budgeting <?>
        Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
        Kernel driver in use: nvidia
        Kernel modules: nvidia
01:00.1 Audio device: NVIDIA Corporation GF119 HDMI Audio Controller (rev a1)
        Flags: bus master, fast devsel, latency 0, IRQ 17
        Memory at fe7fc000 (32-bit, non-prefetchable) [size=16K]
        Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
02:00.0 Ethernet controller: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet (rev b0)
        Subsystem: ASUSTeK Computer Inc. Device 8226
        Memory at fe8c0000 (64-bit, non-prefetchable) [size=256K]
        I/O ports at dc00 [size=128]
        Capabilities: [40] Power Management version 2
        Capabilities: [48] MSI: Enable- Count=1/1 Maskable- 64bit+
        Capabilities: [58] Express Endpoint, MSI 00
        Capabilities: [100] Advanced Error Reporting
        Capabilities: [180] Device Serial Number ff-f3-d4-a0-00-22-15-ff
        Kernel driver in use: ATL1E
        Kernel modules: atl1e
03:00.0 IDE interface: Marvell Technology Group Ltd. 88SE6121 SATA II / PATA Controller (rev b2) (prog-if 8f [Master SecP SecO PriP PriO])
        Subsystem: ASUSTeK Computer Inc. Device 82e0
        Flags: bus master, fast devsel, latency 0, IRQ 16
        I/O ports at ec00 [size=8]
        I/O ports at e880 [size=4]
        I/O ports at e800 [size=8]
        I/O ports at e480 [size=4]
        I/O ports at e400 [size=16]
        Memory at fe9ffc00 (32-bit, non-prefetchable) [size=1K]
        Capabilities: [48] Power Management version 2
        Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit-
        Capabilities: [e0] Express Legacy Endpoint, MSI 00
        Kernel driver in use: pata_marvell
        Kernel modules: ahci, pata_marvell, pata_acpi, ata_generic
04:00.0 USB controller: VIA Technologies, Inc. VL80x xHCI USB 3.0 Controller (rev 03) (prog-if 30 [XHCI])
        Subsystem: VIA Technologies, Inc. VL80x xHCI USB 3.0 Controller
        Flags: bus master, fast devsel, latency 0, IRQ 44
        Memory at feaff000 (32-bit, non-prefetchable) [size=4K]
        Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [c4] Express Endpoint, MSI 00
        Kernel driver in use: xhci_hcd
        Kernel modules: xhci_hcd
05:01.0 PCI bridge: Hint Corp HB6 Universal PCI-PCI bridge (non-transparent mode) (rev 11) (prog-if 00 [Normal decode])
        Flags: bus master, medium devsel, latency 64
        Bus: primary=05, secondary=06, subordinate=06, sec-latency=64
        Prefetchable memory behind bridge: f4000000-fbffffff
        Capabilities: [80] Power Management version 2
        Capabilities: [90] CompactPCI hot-swap <?>
05:03.0 FireWire (IEEE 1394): LSI Corporation FW322/323 [TrueFire] 1394a Controller (rev 70) (prog-if 10 [OHCI])
        Subsystem: ASUSTeK Computer Inc. LSI FW322/323 IEEE 1394a FireWire Controller
        Flags: bus master, medium devsel, latency 64, IRQ 19
        Memory at febff000 (32-bit, non-prefetchable) [size=4K]
        Capabilities: [44] Power Management version 2
        Kernel driver in use: firewire_ohci
        Kernel modules: firewire_ohci
06:08.0 Multimedia video controller: Internext Compression Inc iTVC16 (CX23416) Video Decoder (rev 01)
        Subsystem: Hauppauge computer works Inc. WinTV PVR 500 (1st unit)
        Flags: bus master, medium devsel, latency 64, IRQ 17
        Memory at f8000000 (32-bit, prefetchable) [size=64M]
        Kernel driver in use: ivtv
        Kernel modules: ivtv
06:09.0 Multimedia video controller: Internext Compression Inc iTVC16 (CX23416) Video Decoder (rev 01)
        Subsystem: Hauppauge computer works Inc. WinTV PVR 500 (2nd unit)
        Flags: bus master, medium devsel, latency 64, IRQ 18
        Memory at f4000000 (32-bit, prefetchable) [size=64M]
jmd0 work # fdisk -l /dev/sd?
Disk /dev/sda: 80.0 GB, 80026361856 bytes, 156301488 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk label type: dos
Disk identifier: 0x000cce52
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *        2048     2050047     1024000   83  Linux
/dev/sda2         2050048   139642879    68796416   83  Linux
Disk /dev/sdb: 4000.8 GB, 4000787030016 bytes, 7814037168 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x00000000
/dev/sdb1               1  4294967295  2147483647+  ee  GPT
Partition 1 does not start on physical sector boundary.
Disk /dev/sdc: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
Disk identifier: 0xf2786d18
/dev/sdc1              63  3907024064  1953512001   8e  Linux LVM
WARNING: fdisk GPT support is currently new, and therefore in an experimental phase. Use at your own discretion.
Disk /dev/sdd: 4000.8 GB, 4000786149376 bytes, 976754431 sectors
Units = sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
Disk label type: gpt
#         Start          End    Size  Type            Name
 1         2048    976736255    3.7T  Solaris /usr &  zfs
 9    976736256    976752639     64M  Solaris reserve
Disk /dev/sde: 4000.8 GB, 4000786149376 bytes, 976754431 sectors
 1          256    976754425    3.7T  Linux filesyste Linux filesystem
Disk /dev/sdf: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
 1           40   3907029134    1.8T  Linux filesyste Linux filesystem
Disk /dev/sdg: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
 1           40   3907029134    1.8T  Linux LVM       Linux LVM
Disk /dev/sdh: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
 1           40   3907028991    1.8T  Microsoft basic Linux/Windows data
Disk /dev/sdi: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
Disk identifier: 0xb8389d40
/dev/sdi1            2048      526335      262144   83  Linux
/dev/sdi2          526336  3907029167  1953251416   bf  Solaris
jmd0 work # zfs list
NAME                          USED  AVAIL  REFER  MOUNTPOINT
zfs_2t0                       818G  1009G    32K  /zfs/zfs_2t0
zfs_2t0/bacula_backup         120G  1009G   120G  /zfs/zfs_2t0/bacula_backup
zfs_2t0/mythdata              697G  1009G   697G  /zfs/zfs_2t0/mythdata
zfs_2t0/mythdata/recordings    30K  1009G    30K  /zfs/zfs_2t0/mythdata/recordings
zfs_2t0/mythdata/videos        30K  1009G    30K  /zfs/zfs_2t0/mythdata/videos
zfs_4t0                      1.49T  2.07T   232K  /zfs/zfs_4t0
zfs_4t0/bacula                413G  2.11T   380G  -
zfs_4t0/distfiles            50.8G  2.07T  50.8G  /zfs/zfs_4t0/distfiles
zfs_4t0/downloads            30.6G  2.07T  30.6G  /zfs/zfs_4t0/downloads
zfs_4t0/emulation             781G  2.07T   781G  /zfs/zfs_4t0/emulation
zfs_4t0/isos                 53.7G  2.07T  53.7G  /zfs/zfs_4t0/isos
zfs_4t0/lxc                  13.5G  2.07T   152K  /zfs/zfs_4t0/lxc
zfs_4t0/lxc/vs_mail          4.88G  2.07T  2.89G  /zfs/zfs_4t0/lxc/vs_mail
zfs_4t0/lxc/vs_svn           8.61G  2.07T  8.42G  /zfs/zfs_4t0/lxc/vs_svn
zfs_4t0/medical_images       24.2G  2.07T  24.2G  /zfs/zfs_4t0/medical_images
zfs_4t0/music                4.84G  2.07T  4.84G  /zfs/zfs_4t0/music
zfs_4t0/mythdata             7.46G  2.07T  7.46G  /zfs/zfs_4t0/mythdata
zfs_4t0/mythtv_isos          91.7G  2.07T  91.7G  /zfs/zfs_4t0/mythtv_isos
zfs_4t0/portage_packages     6.67G  2.07T  6.67G  /zfs/zfs_4t0/portage_packages
zfs_4t0/swap                 17.0G  2.08T  9.61G  -
zfs_4t0/temp                 9.18G  2.07T  9.18G  /zfs/zfs_4t0/temp
zfs_4t0/var_tmp              19.6G  2.07T  19.6G  /var/tmp
zfs_4t0/work_data            7.28G  2.07T  7.28G  /zfs/zfs_4t0/work_data
zfs_4t1                      2.28T  1.29T   176K  /zfs/zfs_4t1
zfs_4t1/bacula                136G  1.29T   136G  /zfs/zfs_4t1/bacula
zfs_4t1/emulation             200G  1.29T   200G  /zfs/zfs_4t1/emulation
zfs_4t1/mythtv_parity_0      1.74T  1.29T  1.74T  /zfs/zfs_4t1/mythtv_parity_0
zfs_4t1/win_backups           212G  1.29T   212G  /zfs/zfs_4t1/win_backups
zfs_4t1/work_data            6.16G  1.29T  6.16G  /zfs/zfs_4t1/work_data
zfs_4t2                      2.52T  1.05T   160K  /zfs/zfs_4t2
zfs_4t2/bacula                413G  1.27T   180G  -
zfs_4t2/mythtv_parity_1      1.72T  1.05T  1.72T  /zfs/zfs_4t2/mythtv_parity_1
zfs_4t2/mythtv_tmp            107G  1.05T   107G  /zfs/zfs_4t2/mythtv_tmp
zfs_4t2/swap                 8.50G  1.06T    76K  -
zfs_4t2/system_images         297G  1.05T   297G  /zfs/zfs_4t2/system_images
Is anybody running a linux ditro on your machine ? Can you please give me the details about your configuration?.
Question: Why?
I use to run Linux as my main OS on my laptop back in college. Then I stopped doing that when I realized I needed Windows XP than Ubuntu/Sabayon Linux/Fedora for certain applications. Nowadays, I just run Linux Mint inside a virtual machine for /'web browsing".......
Question: Why?
Well I am planning to build my first box and want to run ubuntu on it but I have not come across anybody who is running ubuntu on their newly built system.
Ubuntu distro is compatible with the Z87 chipset but want to know the configuration if anybody recently installed ubuntu on the same chipset with Intel i7 4770K processor.
I came across a review written for Asus Z87-A motherboard where the person is running ubuntu on it without any issues.. so I guess it is compatible and I am leaning towards getting the same motherboard that will house i7 4770K.
wow finalizing the parts is so much fun !
Hoss Ubuntu, or any Linux, will run on just about any 586 or later hardware out there. The only sticky points are latest-generation just-released GPUs. Especially AMD cards.
Most hardware will function at a baseline...more advanced hardware features may be lacking. I.e. audio cards, many-button mice beyond L/R/wheel/forward/back etc.
Before you buy anything, I highly recommend that you create a thread here in General Hardware with the answers from this sticky in it so that you can get a more solid overview of how your build is going to stack up. It is your first build so you should be getting as much info and constructive criticism as possible.
As for Linux, Linux support for mobos have been fairly decent in the past few years.
You shouldn't have any issues. I've had no problems running Linux on Sandy Bridge or Ivy Bridge systems.
At work, I run Ubuntu 13.10 on a Dual Xeon E5 with a Supermicro X9Dia motherboard. System is rock stable, and everything works.
Great, thanks for the info skripka, I feel better :)
Dangman, the first thing I did was to post a thread with answers to all the questions from the sticky:
http://hardforum.com/showthread.php?t=1814959
:D
Great, I guess in that case my two biggest componets (processor and motherboard) are finalized :)
:D
LOL!
I don't think they are. In your last thread, you clearly didn't have the budget for the Core i7 4770 (not overclock capable) let alone the Core i7 4770K (overclock capable). Hence why Tiraides had to go with the FX-8200 and moderate priced motherboard. Did you increase your budget by another $250 to $300 or something?
In addition, you weren't all that clear on overclocking. So why are you going for an overclock capable CPU and motherboard when past answers showed that you don't know what it is?
LOL!
Well I must admit that when I created that thread, I hadn't started any research.. then I started reading more and more about the hardware. I am planning to build my machine in around one months time so if you read that thread.. people suggested me to post my configuration when I am ready to buy :)
The hardware research is addictive and so are the components. In the quest of getting bigger and better and "little bit more" I ended up increasing my budget :D
At this point I am sure I will not be gaming so I would never feel the need to overclock but at the same time I am planning to use the machine for a type of development which would load the cpu pretty good... so I might overclock. :). This was the reason I selected 4770K and the ASUS Z87-A.
i still have a month's time to starting buying the components so I might change the motherboard and go with something else.. :eek: ah this is so addictive :)
You have to be extremely sure that you will be overclocking in order for the higher costs for the Z87, "K" series CPUs, and good quality 3rd party HSF (you'll need one to overclock well) to be justified. It cannot be a "maybe in the future". It's a yes or a no type of deal IMO as that can mean an extra $80 to $120.
right now both 4770 and 4770K are at same price at NE.
Right now yes, the two are the same price. But last week they weren't the same price: There was a $20 to $40 price difference between the two CPUs. Remember what I said in your other thread?:
Due to the fast changing pricing and availability of computer hardware, a PC that we recommend one month may not be the same PC we'd recommend in the next month. There have been times where we've had to completely change recommendations after only a week. So yeah, if you want an up-to-date build list, your best bet for that is to ask for advice on that 1-3 weeks before you buy.
So in a month from now, the 4770K would not be a good choice if you're not 100% sure about overclocking as it could go back to its normal price of $330 to $340.
http://www.newegg.com/Product/Produ...S&percm=19-116-900:$$$$$$$;19-116-901:$$$$$$$
Here is the comparison of both and the tech specs for 4770K does not say it can be overclocked ??
This is where following hardware news/information for the last several years comes in handy: Intel has only allowed the "K" series CPUs to be fully overclocked for the past 5 years or so. It's pretty much a given at this point in time that you need a "K" series to overclock.
Here is my newbie question:
What factors make a motherboard overclock capable ? or when we look at the motherboard specs .. how do we know that it came take an overclock-able cpu ?
Easy for Intel: They just lock out overclock features on any motherboard not belonging to the overclock capable chipset platform. In other words, in this case for LGA 1150 mobos, Intel is only allowing you to overclock on their Z87 motherboard chipset for the time being. So thats how you know if the mobo can technically overclock: Look at the chipset. No Z87, no overclock.
With that said, just because the motherboard is a Z87 motherboard does not mean it can overclock well. It just means it has the option to overclock. Whether or not a motherboard can really overclock well is best found out by reading as many proper reviews of that motherboard you can find.
Oh wow thanks for the info, I will read more on chipsets..
Oh and in addition to the difference in CPU pricing, there's also the difference in motherboard pricing. Right now, you can get a solid non-overclock motherboard for around $80 to $90. If you're overclocking, you're looking at around $120 to $140 for the motherboard. So that's a difference of $30 to $50 just for the motherboard.
Then there's the requirement of a 3rd party HSF to overclock. Unless you live in a hot/warm area and cannot afford to run the AC all day long, more than likely the stock HSF that comes with most Intel CPUs these days will be good enough cooling wise. But once you overclock, you're going to need a 3rd party HSF to handle the extra heat coming from an overclocked CPU. You're looking at $30 to $50 minimum for a solid HSF
Now you can see what I meant when I said "It's a yes or a no type of deal IMO as that can mean an extra $80 to $120."
I totally agree with you. So if I go with a 4770 then what are my options for a solid non overclocking MB ? I have to go with some other chipset right ?
ok so Intel core i7 4770 and H87 chipset.
You technically don't have to go with another chipset. There have been situations where a Z87 mobo would be a better fit even with a non-overclock capable CPU since the OP had certain feature requirements found only on Z87s.
You're still 1-2 months away form buying the parts. So it would do you no good to look at specific mobos at this time. Again, our parts recommendations do change over time on account of pricing and availability.
