Any significant difference?
nammer21
Trying new build with help from cousin.
He recommended
Asrock Wolfdale1333-D667 Socket 775 Intel 945GC A2 + ICH7 Chipset Dual-Channel DDR2 667/533Mhz Support Core 2 Duo 1333Mhz FSB Micro ATX
http://canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=017070&cid=MB.157
but going through the budget builds, seems like people are using this
Gigabyte GA-P35-DS3L Socket 775 Intel P35 + ICH9 Dual-Channel DDR2 1066/800/667/533Mhz GigaLAN 8-Channel Audio Support 1333Mhz FSB
http://canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=015018&cid=MB.157
It would have e4500 and 8600GT w/possibly 4gigs Ram and he will possibly OC. Is it worth the $40 difference? Thanks.
you're going to lose a bit of gaming performance by having to nurf your ram to 667mhz on the asrock board.
Personally, I'd get the IP35-E when it's on rebate. Ends up being $65 or so, and it's definitely the equal of that Gigabyte board.
