Any point in using AS5 on DS3?
mle
Questions:
If I remove the the Northbridge heatsink off the Gigabyte DS3 and put on DS3, will that void the warranty? What is Gigabyte's policy on this?
Is there any point in putting on DS3 on stock heatsink of Northbridge if I am overclocking, but dont plan to put fan on the Northbridge?
Is there a way to stick a fan onto the northbridge without screws? I dont wish to void the warranty
Only a Gigabyte official could tell you if any of this voids the warranty. I know that DFI says you may change stock coolers, but if you damage the board in the process, that is not covered under warranty. I would guess Gigabyte may have a similar policy, but I do not know.
The stock NB cooler has one of those foam thermal pads. They aren't the best heat conductors to begin with, and they become more like insulators (bad!) as they dry out.
What I did on mine is I carefully removed the stock cooler and replaced it with another cooler. The main reasons for that were both improved cooling, and also to use a reduced height cooler. The stock cooler is too tall and doesn't allow some CPU coolers to be used (like the XP-120 I'm using now).
This is the cooler I used:
http://svc.com/vc-re.html
It's a heavy copper cooler with folded fins and does a good job. Using this cooler means I was able to keep the stock cooler in stock condition (with the factory pad) and re-attach it if I need warranty service on the mobo.
Yep, you con hold a 40mm fan on top of the stock cooler with a few zip ties. The top of the cooler has "hooked" fins and it you can run the zip ties under the hooked sides of the cooler and over the fan. That would at least give you improved cooling without removing the stock cooler.
I'd highly suggest you go active cooling on the northbridge. Have you felt how hot it gets when you run high fsb's? Insane.
As for as5, I doubt gigabyte would give you a hard time about that, but if you're really concerned, don't bother. The fact that the heatsink is able to get SO HOT means that the conductivity of the foam pad isn't too too bad. I feel active cooling is more or less essential on the ds3.
A 40mm fan is the cheapest solution...or mount an 80mm one hanging over it with something like a Zalman bracket (usually not too expensive).
I had a DS3 and didn't touch it. I put AS5 on my P5W and the difference really isn't all that great from what I can tell. Both get very hot and I never had stability issues with either as long as the case has good airflow.
does the heatpipe like on the DQ6 help with the northbridge heat? I was going to put a fan on the northbridge, but realize its not really possible with the heatpipes, although I could do something like the zip ties or mounting one above it..but is it really needed or effective with the heatpipes?
