LstOfTheBrunnenG said:None at all. You see, nobody's actually tried to buy one yet, but if they did. they'd find out that the CPU doesn't even run code. It's not even a processor! It does have a shiny heatspreader though, and a nifty keychain attachment. Mmmmm, keychain.
All sarcasm aside, the difference between it and an E6400 is the fact that it has a 266 MHz higher clock speed. That means it does things faster. Some people will pay more money for a faster PC. Hence, merit.
Case in point: while most have moved on from their beloved 2.4Cs that everyone and his brother had back in the day, some people bought 3.4Cs. If they still have them, they still make formidable systems, even in the face of the releases of Prescott, the A64, the Pentium D, the Athlon 64 X2, Conroe, and quite possibly K8L. Such a system won't win 3dMark06 any time soon, but that game doesn't take any skill anyway.
gersson said:The e6700 has a 10x Multiplier which can help remove any FSB mobo limitations.
Also, the theory is that the higher level processors have more OCing overhead.
I bought an e6700 and a P5W DH... I'll post my results when it comes in later this week.
todlerix said:theres a big ass chart of overclocks of core 2 duos![]()
aamsel said:Wow, and I guess they are faster than my 80286, 80386, and 80486 were, not to mention my 4.77MHz 8088 which ran just fine!!
Seriously, I am FULLY aware of the difference in specs between the E6600 and E6700 and between both of them and the E6400 (which I didn't ask about.)
I have only to this point tested several E6600's with several motherboards and have resisted the temptation to "waste" money on an E6700 based on the test results posted here and on other forums.
Basically, I was asking if anyone had kickass results from particular E6700's.
Thanks,
Andrew
LstOfTheBrunnenG said:Then you should have stated that you were specifically looking for OCing experience. The word "overclock" wasn't anywhere in the OP. We've had two threads today asking whether a Core 2 Duo was any better than a Pentium 4, so yes, it's not too much of a stretch to imagine that someone would be asking if there was any difference between an E6600 and an E6700. That is, after all, what you asked, so that's the answer I gave you.
And from your 8088 comment, you seem to have misunderstood me. I wasn't making a case for not buying a Conroe, I was making a case for buying an E6700 and sitting on it until you simply can't use it anymore. Again, if you were simply struggling to understand the difference between an E6600 and E6700 and why one was deemed more valuable than the other, that may have been a helpful example.
Oh, and the E6400 was a typo. Which I just fixed.
BillParrish said:Dude, change the clock crystal in that puppy, at 5.34 MHz you almost cant see the cell values change in a big Lotus spreadsheet !![]()
ManicOne said:With these chips its all about the multi. I'd take a 10 multi over a 9 any day of the week. Either way they both rock, so either save some money and go 6600, or spend some more and clock your arse off.
Take into account that the difference in price could buy you a water cooling setup......ohh the possibilities.
aamsel said:I am sorry, I really didn't mean to "sound" obnoxious in my reply.
Thanks for your comments....REALLY.
Andrew
Lich said:I can reach 6700 speeds on my 6600 with 533mhz RAM. No reason to buy the 6700 in my opinion
