Any major difference between these mobos?
Nosenuggets45
I'm curious as to which of these mobo's are better to overclock my Intel E8400?
ASUS P5E
ASUS P5Q Pro
Is there any reason to spend over $80 for that other mobo? Also being I'm on a budget here, is it worth it?
For better overclocking, go with the Asus P5Q Pro. The P45 chipset has been shown to OC a bit better than the X38 chipset. However if you want full x16/x16 speed Crossfire, then get the P5E.
But honestly though, the P5E is not worth the extra $80 over the P5Q Pro.
Well the Crossfire doesn't matter to me because I have a GTX 260 with no plans of SLI or crossfire.
Just to give you a second opinion, I agree with Danny. The P5E is certainly not worth $80 over the P5Q Pro, and the P5Q Pro will also probably overclock better, especially if it will be used with a quad.
Good point. Think i should spring for it or wait then?
Not to hijack >_>.
I dunno, honestly. There's always a better deal on the horizon, but if you keep waiting for something better, you'll end up waiting forever. It all comes down to when you decide you want to make your purchase.
go for it man, i the same deal :). Just waiting for my 4850 to arrive and put my baby together.
Yeah, i have an 8800gt i've been using. Opty 165 wth 2 gigs ram on XP. thinking the e8400 will be a considerable upgrade. Debated quad vs dual for awhile, and ultimately I really just game, so.. no biggie.
First intel tho. haha.
