Heres my comp specs. Feel free to ask for more info if needed
3500 winchester
Chaintec vnf4 (lastest drivers)
x800 XL (lastest drivers)
seagate 160 gig 7200 rpm
450 20 pin Raidmax ATX12v (I do have the 4 pin going to the mobo)
1 gig G.Skill pc3200 in dual channel
Installed windows and all was well until I got a VPU error. Thats just the beginning. From what Ive read it was most likely drivers or a gimped graphics card, but ofcourse my problems don't end there. Windows decides to take a crap and I find my self formatting my hdd and re-installing windows, but no matter how many different discs and versions I use (Xp, xp sp1, xp sp2) during the installation It keeps saying that it cannot find certain files on the disc. data.cab is the main one but if I keep hitting enter all of the other ones just go through anyways. Once I get into windows, its just error after error. One specifically was a memory dump issue. I have a feeling that it is my hard drive failing, but any help as to what it could possibly be would be greatly appreciated.
Thanks.
Quick edit: Another error, setup was unable to verify drive c:
Should I just return it???
3500 winchester
Thanks.
