1.1.2.3.5...
- Jul 13, 2006
I've been running my main system with an older ultra x connect 500 watt psu and I know I needed to upgrade this soon. While it still works well enough with this psu and a 20 to 24 pin connector I plan on upgrading the video card. Will the Antec TP II 550 be a good choice for this system?
mobo Asus a8n32- sli deluxe
cpu athlon x2 4200+ 939 @ 2.42
evga 7900 gt ko sc (getting the 7900gtx)
2 gb corsair 3500ll pro @ 220
Maxtor 200gb ata 133
sony dvd burner
SB live (I know, it's old but it still works)
corsair nautilus 500 liquid cooling for the cpu
5 in 1 card usb card reader
I just want to make sure that with this power supply I get can handle the 7900 gtx and likely a 4800+ x2 cpu @ 2.6.
I can get this psu brand new for cheap, but if it doesn't have enough power for what I want, then I need to know.
Thanks
sony dvd burner
Thanks
