When cutting this plastic piece, I needed a more precise hole than the previous piece, so I went ahead and used a cutting wheel to cut well inside of the circle I drew... I then used a grinding stone attachment on my dremel to expand the hole to the needed size. It took me around 30-45 minutes to finish the hole in this piece probably...
Breathing in steel probably isn't a good idea, so make sure to be safe and use goggles and a face mask...
I started cutting out the hidden 3.5" bay area... Unfotunately for me, this part is connected to the motherboard tray, so it's a pain to cut it out... I made a little extra room for myself by cutting out the piece you can see in the 2nd picture...
This is about as far as I am so far... Oh and don't mind how sloppy the cutting job looks inside the case, it will be pretty when I am done
