I just got an antec p180 and put all my old parts in it. I have a few questions as I see a lot of people are experienced about it on here.
#1
While building my case, I believe I used the wrong thumbscrews for the hd cages and now the side door will not come off no matter how much force is used. Should I just rip it off and break the latches and get a replacement from Antec? I probably used the thumbscrews that were for the part that slides back and forth for the wires. I had no idea that this could happen until I searched for why my side door wasn't coming off.
#2
Has anyone successfully fit 4 hd's in the lower cage? If so, did you use round cables or ribbon cables to thread through the hole to the motherboard, or did you just go towards the other side? I used flat ide cables and actually got them both through the hole. Problem is I think the sides are cutting into the ribbon. I noticed a little bit of this happening and all of a sudden now my drives cannot be read from.
#3
Has antec fixed their warped front door problem for the p180 yet? And should I get a replacement for that part too?
I would really like an answer to #1 as that is the most urgent because I really need to access the inside of the case because my vid card fan is dying and I have no idea why I cannot access my drives from my OS. I searched around and found some people just ripped it off. Is there no other way?
#1
#2
#3
