hey all, just installed my new NEOHE into my rig, and after about an hour of wiring (took me forever to figure out how to get everything that needed a molex a connector) i finally boot it up. boots up fine using the overclock that i had set, so i decide to set it back to stock, just to make sure everything is ok. now comes the problem/error message:
when i boot up, it goes past the ASUS logo, then screen goes black and i hear a series of beeps and a message that pops up from the BIOS (says Phoenix BIOS and whatnot) The message says:
Warning: H/W Monitor Status Abnormal
Please Enter the SETUP to Check Voltage, Fan Speed or Temperature Status
so i click on Delete and go into the BIOS, and go to hardware monitor
I see my 5V line fluctuating into the red and out: Goes down to 4.78 in Red, and then back up to the 4.8's and normal
So i'm assuming my 5V rail is low? should i just go into hardware monitor and when it dips that low, hit enter and say to ignore that reading? because i've rebooted several times, each one with the same result. the message allows me to boot into windows fine and whatnot
checking ASUS Probe 2 (which i know isn't a good read for the most part), my readings are this:
+12V - 11.584 to 11.648
+5V - 4.784 to 4.945
+3.3V - 3.2 to 3.264
VCore - 1.392 (stock voltage) up to 1.5 for a second, which is weird since i'm running at stock
so far the 12V is the same as the readings i got with my 450w modstream at 11.648. but like i said, i know probe isn't a good read, and i don't have a MM to check (nor have i ever done it before anyway)
so any help/tips/thoughts on this issue would be greatly appreciated. thanks
oh and i only have 3 of the cables connected to the power supply, with one sata cable connected to my storage hard drive, and 2 molex cables power my raptor, case fans, fan controller and floppy drive, so it's not like i'm using all power this has to offer...
