I'm running an Enhance flex 300W. I transplanted the internals to the original 150W Antec units case, replacing the power socket with the lead from the Antec, as well as switching plugs on the fans.
I can probably manage a pic later if you'd like.
I don't think a 15mm thick VR is going to fit. A 12.5mm thick drive is already nearly touching the top of the case.can you use thicker 2.5" drives in this case? like a velociraptor?
I can confirm that you can fit a 12.5mm thick 2.5" HD in one of the two 2.5" "bays" in the Antec ISK 300. As you can see in the picture below it sits just a touch below the metal edge of the case. The cover slid onto the case without any issues.If you use the standard HDD tray, it looks like one of the 2 drives can be thicker: a 12.5 mm would probably fit. But (and that's just me eyeballing it) I don't think a V-raptor (which is 15mm thick, right?) would fit. Unless you remove the HDD tray.
Has anyone tried to fit an MSI R5670-PD512 (low profile 5670) or know definitively if it would fit?
The dimensions are listed as 195*69*34 mm from here and the images from the Newegg link above show the fan shroud sticking out slightly in terms of thickness and ever so slightly in height.
Trying to decide between an ISK or SG05 but I'd want something faster than a 5570 and I would really prefer the smaller footprint of the ISK, so I'm hoping this combination will work.
I have the same card in my isk300 and it doesn't fit properly. You can put the cover on the case and close it. However, it will push the card slightly at an angle (not a big deal) and the cooler will be touching the side of the case. The problem is the fans touch the side of the case and creates terrible noise. There are a few options I thought of regarding a fix.
1. Leave the side panel detached as this will keep the cover on the case, but it will detract from the looks. Problems: It is annoying because I cannot close the case and you cannot stand it vertically. However, the vertical issue is not really a problem as during my testing it is not a good position for the ISK300 with the 5670. I played some L4D2 and my temps hit 105C and I put it back to horizontal.
2. Cut a hole in the side panel for the cooler to stick out. Con: detracts from looks.
3. Replace the cooler. Problem: No coolers are available that are slimmer. The dimension is 34mm, but this includes the PCB, chip and cooler. In reality, you need to find a cooler that is at the max of 26mm in height. I found an ideal cooler called the zalman vf100, but it was for OEMs I believe. It is 14.5mm high. Most coolers that are available are around 30mm high. There are some older gpu coolers like the vantec iceberq 4, but I'm not sure if that would handle the 5670 (and mounting would be an issue).
I am using option 1 right now, but I am going to be switching to a different case. I'm going to use the isk300 for another computer than doesn't require a video card.
Well that's a shame. Thanks for the info though, at least I didn't have to find all that out the hard way.
If the mounting holes on MSI's LP 5670 are the same distance apart as those of the normal/reference 5670 design, perhaps a small, slim, single slot stock cooler from one of those could be transplanted to the LP 5670? Something along the lines of this perhaps?
Doesn't seem to be too many of those out there though. Seems like most manufacturers opted to go with thicker than single slot cooling solutions for the 5670.
I do not think it has the standard mounting holes based upon comparing the images. If someone knows the measurements I could pull out the card and measure based on the back side.
However, that XFX heatsink would probably be too tall and would definitely need some modding to remove the piece that covers the RAM at the top. Even then it may just be too tall. It also may not fit due to the components on the MSI PCB. Hard to say.
Mounting holes seem to be 43mmx43mm. So there are plenty of options for mounting, it is just the heatsink size.
The MSI stock heatsink without the fans is about 15mm in height. With the fans and shroud it is about 28mm. The case offers around 20mm of room, but the cover that goes on has about 4mm of space since it is pushed out for the honeycomb vents. So in theory you can go to about 24mm in height.
Finally, the case offers about 63mm in height(from the mounting holes on the card) to the top of the cover.
The L2 pro would need to be shortened two ways to fit into the case. Maybe the aerocool doublepower? You would have to bend the heatpipes so it could become single slot since it is overall 48mm in height. The width is 50mm so it should fit into the case, tough call.
Awesome. Thanks for all the measurements, it's been a tremendous help.
From what you've said it looks like there's about 9mm to work with if you include the popout area for the vent grill. Wonder how feasible it'd be to shoehorn 10mm thick fans on the inside there instead of having fans on the outside. Would need another 1-2mm to try and decouple them from the case cover itself so it doesn't transmit all of its vibrations right through the case.
Hm interesting, I wasn't even aware of that Aerocool Doublepower. Another thing to consider. I'd be inclined to try and make it work with the stock heatsink first at this point, since the other possible solutions may or may not completely work.
I think I feel good enough about this now to pull the trigger on my build. Now my dilemma is, do I bother waiting for ITX Sandy Bridge?
Will a Asus ENGT430 Fit? http://www.newegg.com/Product/Product.aspx?Item=N82E16814121397&cm_re=gt_430-_-14-121-397-_-Product
I read that the cooler is 0.75 inches thick or roughly 19mm, is this cutting it to close?
I saw Sparkle has a single slot cooler on a 430 for the same price roughly.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814187135
Might be worth looking in to.
Yeah the HD 6000 cards have been amazing in the segments they're offered so far, mostly more efficient so that'd lend itself greatly to low profile cards, I'd imagine.
By the way, I am thinking about building a new ITX Sandy Bridge PC, and was wondering about the 65W power adapter in this case.
Would I be able to just buy another power brick or would I have to get a different DC-DC converter as well?
I am thinking either i5 2500 or i7 2600 (not sure yet) and a low profile video card on par with that GT430, so it'd need a decent amount of juice, and I highly doubt the 65 would cover it lol. I'm considering the 310-150, although the DC-DC converter would obviously be quieter so I'd like to go that route if possible.
Thanks!
Thanks!
Between the 65w and 150w versions are there any reasons to get the 150w psu other than the extra wattage? I'm looking at building a zacate system once boards start hitting and plan to be in the sub 60w area.
Anyone still playing around with this case? I was doing some shopping for a new low profile card, and thought I'd check in
This would be epic with this case
http://www.hardwaresecrets.com/news...Mini-ITX-Motherboard-With-GeForce-GT-430/5298
But no news so far
I saw that too, it is a neat card but it would only work in a few cases (EG: antec nsk1480) where their is enough headroom on the PSU.Yeah...the choices out are pretty...meh. I guess I'll be waiting for the hd 6570 or 6670.
On a side note, I just saw this a page over:
http://hardforum.com/showthread.php?t=1595218
That looks pretty cool. I would only purchase it if it had dedicated memory on the motherboard. It seems like it would be a good fit for the isk 300 .This would be epic with this case
But no news so far
