Antec GX 202 case (nice)
Astrowind
I've used several different cases in my life for builds but this is probably the first time I'm satisfied (without modifying it). I ordered the Antec GX202 mid-tower computer case and received it today.
Here are the strong points to me:
- large power and reset buttons near the top of the case
- no ventilation holes on the top or side for front to rear air flow
- drive bays are aligned in the same direction
- nice-looking, compact design
- ventilated mesh front
- only one front port for optical drive (I usually only have one)
- side transparent panel (to see if fans are still working, although it's dark tinted)
- fans that light up (although I'll likely use one in the back and put the other one in another case that has a window on the side)
Even if I haven't used it yet, I decided to buy it even though my next build may be next year. The last times I've seen things I wanted to buy in the style I liked, the items sometimes were no longer available by the time I thought about buying them.
Let me help. Not bad looking at all for a $50 case. I like that it has a 5.25 bay for optical, those are almost extinct but I still use them. Even Antec's budget stuff is pretty good.
Dust filter on bottom for power supply intake is always welcome. And I assume the entire front mesh part acts as a dust screen since there isn't another one under it I can tell.
Stolen from www.newegg.com/Product/Product.aspx?Item=N82E16811129241
Oh that pic didn't have the LED fans on. Just white, no LED. I kind of like that. I also like the mesh front instead of the new trend of putting solid acrylic or glass in the front which murders airflow at the cost of looks.
Oh, I see a chink in the armor. Not that surprising since it's a budget case, but the hard drive mounts are faced inline, and doesn't have modular/removable bays to remove ones you don't use. So 2002. Every case now should have hard drive bays that are sideways mounted facing out, for easy install/extraction. With a huge inline bay, you can get blocked off by motherboard/video card, etc. My Antec 300 is like that and it's a ROYAL pain to install or remove hard drives with motherboard installed.
I guess if you only have 1 drive it's not a huge deal. Those SSD mounts are weird. There are 2 on each side and it looks like they mount inside the inline bay, but vertically for a total of 4. Then again, with M.2 SSD becoming more popular, drive bays are getting less necessary all the time. I would have loved if they had just put 2 x 3.5 and 2 x 2.5 near the top below the 5.25 bay, then just chopped the rest off. But I guess that is what dremels are for. OTOH the drive bay probably has a lot to do with case stability/rigidity since it's a budget box. Cutting it out might make it wobble (-er?) ?
Sorry I hijacked OP's thread, LOL. I got all excited about a decent new budget case.
I didn't really think about the fact side drive bays would make it easier to take them out later but usually, I don't replace drives.
