I just recently put an Asus P5E-VM HDMI along with the basic components (CPU, Memory etc). I also installed Vista onto the system.
I successfully installed the LCD drivers and works just fine.
I can't manage to get the volume knob to work with Vista. The "VFD" driver is installed and I'm able to customize the settings. When I go under the "Audio" tab, it doesn't see any type of "Audio" device or driver. Even though under Device manager it shows as installed. Anyone have any ideas on how to make the volume knob to work with Vista?
On the side note, when I turn the know, the LCD driver sees that it's being turned but as far as the actual volume itself, it doesn't work due to the fact that the "Audio" tab doesn't see any type of "Audio" device.
