And the drive cages are easily removable.
Danny,
My main rig is now housed in a CM690 II Advanced case, which sells for a bit more than the basic CM690 II. Most of the extra $15 or so goes to the SATA HDD dock on top of the case. This allows the use of "internal" SATA HDDs for additional off-site (or more specifically off-computer) storage.
Between just the 900 and 900/2, I'd definitely go with the 900/2.This is because both of those cases are surprisingly cramped on the inside (from rear to front). Long graphics cards will not fit inside either of those two cases. And motherboards which put the SATA ports out of the way of longer expansion cards (at the front edge of the motherboard) must be completely dismounted from the case just to connect additional internal storage drives because access to those ports is blocked by the permanent 5.25" drive cage frame. The stock fans are also surprisingly noisy given their size and cooling ability.
