Antec 900 - configuring front intake fans
TehQuick
So, I'm experimenting with various fan placements. As you all know, the case ships with 2x120mm intake fans, placed in lower part of the front of the case but it's easily changeable.
By default, fans are blowing on the psu, lower portion of the mobo and videocard. Well, I wanted more air in the cpu area, so I moved one hdd cage (empty) 2 notches up, and now it's blowing over memory modules, cpu and NB a little bit. I moved the lower cage one notch up. Here's how it looks, schematically:
My third intake fan is on the side door. Now, the front fans are very slow (1000rpm or so), side door is around 1100-1200 (Antec tricool at low). My 2 exhausts are at low (120mm) and med (200mm).
Now, my question is whether this is a good setup. Taking off the side door drops load temps by about 4-5c. I would appreciate if other owners of 900 would chime in with their setups for intakes on 900.
ive actually never thought of moving the fans up, is it just ez as that? removing the screws and pulling it out and then moving it?
The best 900 setup, as far as I'm concerned, and the one I'm using:
Put optical drive in bottom slot. Put 120mm Fans (each taking up 3 slots) in the top 6 slots. Cover 2 remaining slots.
What's the point of having fans at the bottom-front of this case, or any other? Every single case should have a front intake directly across from the CPU and memory area. I'm not worried about my PSU overheating. That's the least of my concerns. I have to take care of my Northbridge, 8800 and CPU in that order. If you put a fan on the bottom of this case, all you're going to be cooling is cables. ;)
Jomanscool2 - Duh, that's why I'm posting this thread, and I would appreciate a more constructive post rather than pointing out the obvious.
Al Shades, interesting idea but I don't want to have a hot pocket at the bottom, especially since I'm gonna be placing the pump there pretty soon. Although, I'm thinking about putting 2 blanks at the bottom, and putting an 80mm fan behind it just for the pump, two cages above that and dvd at the very top.. doesn't leave much space for other dvds but I guess I can try that for now :)
soulesschild, yup, this case is pretty cool with the number of options for placement of the front intake fans, that's why I decided to mess around with that. In fact, if you switch to an external drive, you can have 3x120mm intake fans, because you don't really need HDD cage to attach the fan to the front of the case ;)
My purpose is to find ideal placement for front intakes without resorting to setting them on high. I love the quieteness of Antec 900 with all fans on low (not silent but pretty quiet), so I hope to keep that and have good airflow, as well :D
