night_2004
- May 31, 2007
I'm thinking about replacing my heatsink fan, but need some idea of how many CFMs I need in order to get the job done.
My heatsink (Dark Knight S1283V) comes with a 120mm fan that outputs almost 90CFM at full blast, or 2200RPM. 99% of the time my fan is running at only 20%, which is great as I do not really hear the fan at those speeds as other noise drowns them out. At least right now I cannot hear the fan below 50% and that gives me enough cooling capability that my CPU barely touches 70C at full load with IBT.
But I've got some new parts coming in (quieter 140mm fan, almost silent PSU) and I expect that either the GPU fans or CPU fans will become the loudest component in the system. So the next thing on my "how to silence" list might be to swap out the CPU fan. Can't do much about the GPU fans without going to custom cooling (no thanks for now).
The 120mm case fans I use I literally cannot hear beyond a few inches away from the case (44CFM, < 20dBA). So I was thinking about putting two of them in a push-pull setup on the heatsink and running them full bore. Or maybe just one, depending on what kind of airflow I get.
So here's the question...does the CFM output roughly scale linearly with the fan speed?
