- Dec 28, 2006
Finally got my system up and running and all is well. I have the Q6600 clocked to 3.0GHz at my stock voltage(1.2v) which is actually about 1.14v after v-droop. Needless to say , I have excellent temps. My question is how far apart should the cores temps differ from one another and should that gap close when running Prime95? I'm using Coretemp and at load , I'm getting 42-37-42-36C(1/2 hour in). The cores never seem to get much closer in temps and they are all at 100%. Should I maybe try re-seating my waterblock or just not worry about it. I'm very anal about stuff so this is kind of eating at me. The thumb screws are all adjusted to the same exact tension as I measured threads with a machinist ruler
U I suppose the springs tension could be a little different but that's me thinking way too much!
Another question - when the cores are numbered(0-1-2-3) at what orientation are they on the di(e)? I'm thinking I may be able to adjust my tension by knowing what core is where.
