Another Nu B build question
Wingnut225
I'm so glad that I stumbled upon this site. A lot of information and I have spent hours combing through it for my answers. I have taken advantage of some of the Black Friday deals (if you want to call them that) based on the info that I have read on this forum. Please let me know your thoughts and if what I plan to build will work for what I want it for.
Photoshop, Lightroom and web surfing
Around $1,000 USD
U.S. - Northern Baltimore, Maryland
Purchased
Coolmaster HAF 922 case
ASUS P8Z68-V pro MB
Coolmaster Hyper 212 Plus
Corsair Vengeance 8GB (2x4GB)
Corsair 650TX (not the V2, is there a big difference?)
WIN 7 Home Premium SP1 64-bit
Need
SSD - thinking Crucial M4 for OS and programs
CPU - thinking i5-2500K and OC it
2 TB HD that has photos already on it
Original 320 GB HD to keep word documents and other less used programs on. This is until HD prices come back down
DVD burner
card reader
keyboard and mouse - USB
6) Will you be overclocking?
I plan to
Main - HP ZR24w 1920 x 1200
Secondary - 19" Dell res. unknown
for the parts that have not been purchased - in the next week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Nothing specific but I want to take advantage of the USB 3.0 and SATA 6Gb/s. I plan to use onboard video. I have read that this is fine for Photoshop and image editing
No. Purchased Win7 Home Premium 64 bit
Now I am coming from a Dell XPS 400 so the parts that I am reusing are about 5 yrs old and this is my first build.:eek:
My questions are:
Can I run both my monitors from the MB?
As stated above, I want to reuse my existing HD's. They are SATA drives but they use that older 4 pin power connector. Is that a problem?
How does all this sound and am I forgetting anything?
Thanks very much for your help!
Chuck
There's a big difference between the V2 and non V2 650TX as the V2 is newer, updated, and performs a tad better. With that said, if it's too late and too costly to return the 650TX, keep it as it should still work fine.
Your CPU and SSD choices are solid. Same for the rest of the parts you purchases. To answer your questions:
1) Yes as long as you connect the HP via DVI or HDMI and the Dell via DVI or VGA.
2) Not really a problem besides low performance
3) Looks solid to me.
Thanks Danny! I've seen a lot of your posts and I can see that you've helped a lot of people.
