intense99dak
- Sep 4, 2002
Like so many before me I haven't built a system for more than a few years and am hesitant to press the pay button on my orders. I've spent the past week or so here reviewing systems , posts and links and I think I've got everything covered. However, it's a lot of information to process and I'm hoping some patient people here, in between reviewing other systems, will review mine and interject if needed.
I'll be using the system for typical home office stuff as well as heavy gaming, quite a bit of 3D rendering (home architect software) and possibly some video editing down the road. I currently have a 22" LCD, but I'm planning on SLI so I can purchase a bigger, second monitor later. I do plan on overclocking as much as the air flow will allow me.
Here's the specs with questions comments following ...
Silverstone TJ09 case
Abit Ip35 pro motherboard
Q6600 Kentsfield 2.4GHz
Tuniq Tower heat sink
G. Skill 2 x 1GB DDR2 (model F2-6400CL5D-2GBNQ)
EVGA 880GTS 640MB
WD Caviar 250GB SATA HDD's
Asus 18x SATA DVD burner (DRW-1814BLT)
Corsair 620HX
I know the TJ09 case is huge and I read the thread about it, but I can't remember if I need any other extension cables besides a 12" 24 pin. I'm planning on purchasing 36" SATA cables along with new fans for the case (and I have the directions for changing out the front fan).
I'm planning on sticking with WinXP for a while and was wondering what gains, if any, would I see with 4GB of ram instead of 2GB. As I understand it I don't need "better" over-clockable ram with the Q6600. Is that correct?
My current system is causing me a lot of grief now and I'd like to build soon. I realize better technology is right around the corner, but I'm hoping there's enough expansion room in this system to keep me playing games happily for a while.
Thank you for your time and consideration.
EVGA 880GTS 640MB
Corsair 620HX
