Backstory:
My venerable Dell Latitude D600 has started dying...the first DIMM slot is defective, and requires constant pressure on the DIMM for the machine to boot, and using a piece of rubber to hold it down w/ the slot results in a laptop that will hardlock - frequently. I'm running it on a single 256MB DIMM right now.
Question here, really viable to run this machine on a single 1GB DIMM in the second slot? How much perf do I lose with single-channel? Note that 1GB would be a jump over the currently installed 2x256.
Full specs:
1.7 P-M Banias (whatever the 400FSB is)
Intel 8xx (400FSB chipset, so no pin-mod)
32MB Radeon 9000
1400x1050 Screen
160gb IDE HDD
So, now my questions/criteria about a new lappy:
Battery Life
Are there any C2D lappies that can get around 10 hours of battery life with Wi-Fi on, using a combination of regular battery slot + modular bay battery? I enjoy being able to take the D600 around anywhere and pretty much leave it on from first class of the day to the last, and then dock it all without shutting down once. Or should I be looking to purchase a used Core Duo laptop (Core Duo is two Pentium M cores squashed together, right?) for battery life? This is probably my biggest concern...
Other
Dell - preferable, I have a D-Series docking station that I would like to keep using
Dell - NOT an Inspiron/Vostro whatever. I hate the white plastic looks, and also, seems like EVERYONE has one.
Screen - nothing less than 1440x900/1050; if its another D600/D610, I can reuse my high-screen. Also, <17", 17 is waaay too big for me.
RAM - must be DDR2 (should be easy) so I can drop in 2 or 4GB of RAM.
CPU - prefer something 64-bit capable, but that might be a long shot with above reqs, since I think C2D was first 64-bit capable laptop CPU from intel's camp?
Price - ~$1100, willing to go +200 or so. Extended batteries can get expensive.
I had some other thoughts floating around in my head, I'll post as I remember 'em.
Full specs:
32MB Radeon 9000
1400x1050 Screen
160gb IDE HDD
Battery Life
Other
