Another headphone thread
What cans from AKG and Beyerdynamic is comparable to my Senn 497's ? Thanks for the input ! :)
Ah yes, the Senn 497. I know of no direct comparison between the senn HD497 and a beyerdynamic in terms of sound quality..............
Closest I could think of is the DT880 in terms of overall sound quality, but the beyer is leagues above the 497 in terms of comfort and sound quality.
In terms of price and overall size, the DT231 is very comparible to the HD497, though it doesn't sound even remotely the same.
I'm no guru on AKG's, so I don't know which of their budget headphones compare to the HD497.
Personally, if you are looking for a small portable headphone, i'd consider the Senn PX100 over the HD497.
~Hope this helps
