Another economic incentive check upgrade...thoughts?
Daggah
I currently have an AMD X2 4200+ system on a DFI LanParty nF3 motherboard (you guys remember those, right? ;) ) and 2 gigs of RAM. I am thinking about upgrading to a Core 2 Quad setup. Here's my parts list so far:
Motherboard: Gigabyte GA-EP35-DS3P - I wanted an SLi motherboard but I hear that the latest nVidia SLi motherboard chipset is having problems with video corruption, and more than likely I'll never actually use SLi.
CPU: Core 2 Quad Q6600
CPU Cooling: ZEROtherm Nirvana NV120 120mm 2-ball UFO Bearing HSF
RAM: OCZ SLI-Ready Edition 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit
Hard drive: 750 GB Seagate SATA (will be installed in conjunction with the 500 GB SATA drive I currently have, and I'll find some other use for my 300 GB SATA drive)
OS: Windows Vista Home Premium 64-bit
Parts I'll be retaining from my old build:
Video card: BFGTech 8800 GT 512 MB
Optical drives: 16X PATA DVD-RW & 16X PATA DVD-ROM
Power Supply: Enermax 600W Noisetaker
Any thoughts? My main thing that I'm unsure of is the motherboard to be honest. I was always an AMD guy so I never really kept up with Intel's stuff. The Gigabyte motherboard seems pretty solid with lots of features though.
Nothing wrong with your build as far as I can tell.
Have fun with it!
SATA Optical drives would help reduce cable clutter within your case. Are you sure that you need the DVD-ROM?
I have made modifications to my case to allow for routing an IDE cable behind the drive bays and then back into the 5 1/4" bay. If I get a 36" dual device cable I should still be able to do that (in my current setup I use two single device cables.) I like having the DVD-ROM drive for having the option to duplicate CDs or DVDs even if I haven't done that in a while.
