So a few months back I started putting my pc in a hybrid sleep to help with the heat level in my room at night. One day when I woke the pc up it came back up as it should but then started to hang up and then I got a grey screen. When I tried to restart my computer bios still showed the drive but windows took FOREVER to load. Once in windows it started to hang up for 10-30seconds at a time. Computer has been off until now.
Cut to now, finally got a replacement drive of the same size/type. Booted into acronis to try and clone, no dice. It thew out read errors when the cloning process began (direct r/w). It also sounded like the heads were not seeking anywhere. Next I thew it in my blacx and hooked it in my laptop to try it that way. When I plug it up the drive spins up like it should heads go nuts like they are seeking while the drivers are being loaded. Then I try to backup up the drive using acronis on my laptop. Get the same r/w errors and VERY sporadic head movement. The backup size gets to about 3gigs and stops.
At this point I'm thinking of trying the old freezer trick and praying. I had a crackpot idea though. After the drive is 'frozen', would it be worth trying to put it back in the dock and sticking the whole shebang back in the freezer and try to backup/clone with them both in there? Running wires from the freezer to my laptop. Hopefully getting more time out of the 'freeze'.
