Another Computer issue thoughts
Pdwe
I downsized my old computer took it to a local shop.
Specs
CASE: Lian Li 8nwx
Fans: two 120 mm
PSU: Antec truepower 650 watt
MB: Giga-byte EP 45T
CPU: Pentium 4 3.8 prescott socket 775 lba Retail use standard cooler
Ram: Corsair 4 gb 1333 DDR3
Video Card: ATI x700 pro pci-e
Soundcard: Soundblaster Audigy 2 zs
Plextor dvd-rw
Vantec trayless hd hotswap
The issue I notice it I hit power button on it starts for two seconds turns off then turns on again for a few seconds turns off after 4 times it stays on. Fans are going. The repair guy thinks my soundcard is cause and powersupply.
any ideas why this is happening?
Thanks
Replaced soundcard and still having issues.
sounds like you need a BIOS update. sounds like the restart bug that affected many gigabyte boards since the P965 days.
Seems like the reboot bug happens a bit later then what happens to mine. I don't see anything on the screen at all until it stops doing it usually 4-6 times. Sometimes it does fine the first time.
