What is wrong with using HFM.net in Ubuntu?
The fact that you have to manually re-login to network drives after reboot
So there is none then, I assume?![]()
Nah, thanks for that. I've got it installed here (thanks to you how-to).
I am having difficulty to add HFM as a launcher. Any idea on how to do that? Or is there any quick way where I can start HFM without having to "Ctrl-Alt-T > sudo mono HFM.exe"?
cd ~/Desktop
nano HFM.desktop
[Desktop Entry]
Type=Application
Version=0.9.1.595
Name=HFM.net
GenericName=Harlam Folding Monitor
Icon=/home/<user>/hfm/hfm_48_48.ico
Exec=nohup mono /home/<user>/hfm/HFM.exe
Categories=Accessories;Internet;
chmod +x HFM.desktop
Are these Windows network drives you are referring to? If everything is properly set up, you should not need to manually do anything on a reboot. I'd be interested in looking at your setup to see what is going on.
If you guys have a windows machine that is always running, you could toss hfm on that and then create an internal website, which is what I do.
If power draw is a concern, with some elbow grease one of these can be setup to run windows(which is easier for most) http://www.ebay.com/itm/One-Nice-HP...466582?pt=US_Thin_Clients&hash=item4d0b8ff916
These have a socketed cpu/ram, you can also get a DOM or, cf card adapter, ribbon cable, and card to toss windows on. There is a winxpe image avail for these, but not sure if it would allow you to install or not. A stripped down version of winxp or win7(thin pc) would be perfect for this.
Just idea.
Or you can simply use a free account from Dropbox to create that sort of website.
