Recently I've noticed how much of an effect having the computer on in my room has on the ambient temperature. And trying to think of some way to reduce that effect. Now the first thing that comes to mind without thinking about what's really going on, is the computer needs to be cooler.
When I think of getting the computer cooler, I think of a better HSF or finally giving into the urge to watercool, etc. Or choosing some cooler components - not really an option as I like my current stuff for the most part.
Then I started thinking about what's actually happening when you cool your computer. You're transferring the heat out of your case, into the room. The better your heatsink, airflow, etc is, the more heat you transfer out of the computer. So as the computer gets cooler, the room gets hotter. The TDP of the system is the same, the heat is just being moved out of the case.
Simple if you think of it, and maybe everyone already knows this, but for me it was an interesting thought and I figured I'd see if anyone else has some input on the topic.
Personally, what I'm gonna try is making a couple of small hardware changes - a cooler CPU for one, and look into undervolting it and just running stock speeds when I'm not doing real CPU intensive tasks, instead of my max stable overclock all the time.
One thing I'm still not sure about is watercooling. It seems in principal, that it wouldn't be much different in the effect on your ambient temperature, but since water has such a high heat capacity, I was thinking maybe it absorbs some of the heat.
