Spirit_Retro
- Apr 1, 2010
Hi guys...
Recently I picked up a Coolermaster CM690 II case since, while juggling machines, I needed something really well cooled for a GTX 295 SLI setup.
The upshot is that there were a number of problems with the case.
The first problem was that the motherboard tray holes for the standoffs were not tapped. Which I figured wasn't that big of a deal, so I tapped them myself.
The second, and rather serious issue has to do with grounding. This case has ground issues. Anytime any static charge is applied to the case, the computer restarts or freezes. Coolermaster support said it was a faulty USB panel in the top of the case and sent a new one. That did not solve the problem. In fact the new part was electronically and physically identical to the old one.
The case is steel, but it's coated inside and out with a black non conductive coating, and the issue seems to be that any static discharge goes through the path of least resistance (the motherboard standoffs) because of the non-conductive coating on the case.
Anyone else seen these kinda of quality issues with Coolermaster?
I just retired my Thermaltake Xaser II which I've had since it's intro. And it looks like I'm going to eat the cost of this Coolermaster case- they haven't responded in 72 hours. I'm just tired of dealing with it.
So what do you think of the following alternatives:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129043
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129058
Suggestions?
Suggestions?
