AMD's Turbo Core Technology
HardOCP News
[H] News
PCPer has the lowdown on AMD's Turbo Core Technology. Hit the link for all the info and screenshots from AMD’s presentation.
"When the processor determines that three or less cores are being fully utilized, it will place the underutilized cores into a lower power, low clockspeed state. In this case the cores will be clocked at 800 MHz and will have their voltage decreased. The other three cores will be placed into a boost mode, with their clockspeeds increased as well as their voltages per core increased. AMD is designing these cores to be run between 400 MHz and 500 MHz faster. A theoretical six core clocked at 3.2 GHz would then see a boost of three cores up to 3.6 GHz."
Or I can just run my quad core intel at 3.8 ghz full time...
ya curious if say your 3ghz stock is already running at 3.6 normaly wonder if it will go past that.
yeah true, but overclockers already use turboboost on Intel I series for overclocking, don't know why you couldn't do the same for AMD's version, should be just as effective
The real question is if this new CPU is actually worth using at stock speeds. If it's a big steaming pile of shit until you have it overclocked to 4Ghz then this whole turbo boost thing is useless.
