erek
- Dec 19, 2005
"Coreteks' AIB sources also suggest there will be a pair of Big Navi GPUs at launch, based on the same Sienna Cichlid silicon. That's not much of a stretch as this is classic AMD graphics card practice; it's very own rule of two. This typically sees a cut-down card launching alongside the full-fat option. Just think about the RX 5700 XT and RX 5700 last year, RX 580 and RX 570, R9 390X and R9 390… and on and on.
And traditionally we usually end up recommending the lower-spec one as its lower price, and generally only-very-slight specs cut, end up making it a better value card by comparison, offering often very similar performance.
It looks like those two Sienna Cichlid cards will be the only Big Navi GPUs we see this year too, if this report is to be believed. A second fish-based codename, Navy Flounder, has been tied to the new RDNA 2 architecture, and is reportedly a mid-range version of the Big Navi GPU slated for release in the first three months of 2021.
With only the high-end market set to be served at the tail-end of this year, it seems almost certain that most of us are going to have to wait until next year to see anything more affordable than the ultra-enthusiast, ultra-expensive GeForce and Radeon cards."
https://www.pcgamer.com/amd-big-navi-rdna-2-aimed-at-rtx-3080/
