ASUS E35M1-I DELUXE is live on newegg now for those that were wanting fanless.. Too bad its freeking 175 bucks
yea just saw it today...
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131698&cm_re=zacate-_-13-131-698-_-Product
i heart this mobo so [H]ard!!!
i have the intel atom version (check my sig for my HTPC specs), would it be worth it to swap out mobo's? meaning would i see noticeable or minor differences in actual performance? my wife and i mostly use it for streaming content from netflix and hulu.
I finished setting up the Zacate rig for my parents to use as a media streaming box. Unfortunately, I don't think it's fast enough to do Netflix. I was getting bad stuttering and occasional hiccups in the stream, although the CPU usage was hovering around the 50% mark.
Seems odd.. doesn't atom handle netflix ok? Hard to believe that a more powerful CPU would struggle with it. Hopefully it'll get resolved quickly if true, but even so, this is a new product and there are bound to be some hiccupsI finished setting up the Zacate rig for my parents to use as a media streaming box. Unfortunately, I don't think it's fast enough to do Netflix. I was getting bad stuttering and occasional hiccups in the stream, although the CPU usage was hovering around the 50% mark. I think the current version of Silverlight doesn't support GPU acceleration on Zacate yet, and the fix will be in Silverlight 5 which won't come out till the later half of the year.
the CPU/GPU probably aren't powerful enough to do 3D well anyway, so whats it matter? AMD probably took a look at market adoption predictions and realized that only a few jerks with too much money to spend really went after 3D, and that everyone else is happy in flat-land. If it saves me money on Zacate (even if it actually ran 3D well), then I don't careOn the plus side, 7.1 LPCM audio over HDMI works fine. However, as others may have mentioned, it's only HDMI 1.3. Hello AMD, it's 2011. Why are you guys still stuck in the past? Even my el cheapo $100 Sony blu-ray player supports HDMI 1.4.
considering how new the Zacate is, and how hard it still is to get your hands on a ceton, I doubt there are too many people out there running both
That ASUS Deluxe board is damn near perfect:
Passive
On-board wireless
USB 3.0
5 x SATA 6
Bluetooth adapter on back
Now to get my case and picoPSU
I seriously considered building a new zacate rig and then trying it out with my ceton, but I realized I have pretty much zero use for another HTPC and this one is completely fine already... I guess logic wins for now, but something mini-ITX and easier on power would be fantastic.. at about 1/3 of the power draw of my current rig i'd be alot more willing to leave a zacate on 24/7anyone got a zacate they want to let me borrow?![]()
Here's my build. I ordered the parts yesterday. It will be my first HTPC but I think it's going to fit the bill perfectly. Passive cooling and low power consumption were key considerations to me (i'm sick of the damn fan noise from PS3/XBOX 360 etc.).
LIAN LI PC-Q09B Black Aluminum Mini-ITX Tower Computer Case 110W Adapter Power Supply
ASUS E35M1-I DELUXE AMD Zacate E-350 AMD Hudson M1 Mini ITX Motherboard/CPU Combo
G.SKILL Value Series 4GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9S-4GBNT
LG Black Super-Multi Combo Drive SATA Model CT21N - OEM
OCZ Vertex 2 OCZSSD2-2VTXE60G 2.5" 60GB SATA II MLC Internal Solid State Drive (SSD)
Logitech diNovo Mini Black Bluetooth Wireless Mini Keyboard
I would choose the MSI board since any passive cooling needs some active chassis-cooling which is nearly impossible in an mini-itx chassis.
However the german magazine c't just tested all Zacate boards and the msi is the loudest with 1,9 sone which is just horrible!
Some smart guys already ripped off the lousy 40mm fan and installed an 80mm fan on top of the cooler, which works like a charm. However, the height of the whole cooler is now about 70-80mm (including the 80mm fan of course) which means it does not fit into the mini-itx chassis anymore.
It just a shame!! Any ideas btw?
Maybe get a bigger case? One that actually has decent cooling?I would choose the MSI board since any passive cooling needs some active chassis-cooling which is nearly impossible in an mini-itx chassis.
So For those that already have zocate boards. How is the NetFlix playback?
ASUS e35m1 pro
Netflix is flawless. I bitstream audio and play my blu-rays just fine also.
This setup has plenty of power for an HTPC and even some extra oomph for cleaning up the picture on DVD upscaling and de-interlacing.
I thought I was running a low power setup before but now my HTPC idles at 27w. Wow, just wow.
OK maybe you can help me out here.
Netflix is far from flawless on my setup.
15mbps wireless connection (high end router).
I ran lord of the rings streaming movie from netflix, it is filled with stutters and jitters, especialy when the camera pans.
Have you done anything special, like updating the bios? What is your current setup? Operating system and all?
Again I reitirate that netflix is far from flawless, at least for me. I would like to fix it.
Have you tried hard wiring it? I'd eliminate network issues first even if you have super duper wireless.
Would it be stupid to cram that ASUS board into a KT-400? I'm thinking a couple 120mm fans and I'd be done and have an efficient HTPC.
I not sure if I can stream netflix due to being limited to DSL anyways.
Wireless and HD do not mix, hardwire it and try again.15mbps wireless connection (high end router).
