roadkill401
- Jan 12, 2011
Some days it just sucks to be me.
about 6 months ago I built up a AMD X4 II 955 with a Gigabyte MA786GMT motherboard. 8gb Gskill ram and a Corseair 750w power supply.
I had problems getting windows 7 to install but that turned out to be a defective DVD drive. It worked fine for 5 weeks then started to give random BSOD errors. Since it was outside of direct replacement warranty, I started to look into what components could be causing the problem.
Tried moving around the ram, going down to pairs and single stick. Still got the random errors. I found that if I re-installed Win7 clean, the problem would go away for 3-5 weeks.
Replaced the power supply as I could do that without much cost. Problem still persists.
The errors started to be mostly around the ATI drivers, so I disabled the onboard video and put in a new video card. Problem went away for 6 weeks, then came back again.
So bought a new motherboard last week, (ASUS M4A88TD-V evo) and it worked for 1 week before more BSOD errors.
The only thing left that hasn't been replaced is the CPU. Am I just burning money and my sanity, or is it worth seing if I can return the ASUS motherboard with restocking and try a new CPU on the old Gigabyte motherboard?
What would you do?
Matt
What would you do?
Matt
