amd x2 3800+ cpu cooler
urbanlegend786
I have Amd x2 3800+ socket 939 processor and i am trying to get a scythe ninja(SCNJ-1000) cpu cooler but i am not sure if it will fit my processor....
thanks
it will fit your processor for sure but don't know if it will fit your mobo or not, what's your mobo?
Honestly, I can't see going away from the plain XP-90 which you can get for $30 with a fan from www.svc.com. Compatible with just about everything. That's what I use on my 3800+
Yah, hands down the XP-90 is the best deal on a heatsink, go for that.
The Ninja will fit. I've had really good exp. with it. Especially with 2 120's in push/pull.
