bloodypulp
- May 17, 2010
meh.. it's just probably a binned 8350 with a water cooler.
(I have an fx8350 system at 4.7Ghz)
This so-called Centurion is guaranteed to run at 5GHz, on air
hell, i might as well get two of themlimited-edition chip is set to cost a whopping $795
Part of this is a catch22. I mean software developers can not design their software to require 8 cores since not 95% of their target audience does not have an 8 core cpu.
I dont get it?
I have 2 8320's running at the 4.6 Ghz on air on Asus Sabretooth boards. Rumor has it the 8300 can do a bit better, so why is it even "a thing" that they could crank out hand selected chips that can do 5.0Ghz?![]()
Did I read that right? $795? That sounds more like a G34 socket chip than an AM3+
The problem is that AI and other game logic is highly-dependent on game state. AIs need to know about not only the environment, but they need to know how to react to players (and there could be more than one) and how to 'mingle' with other AIs. They have to talk to each other, and that incurs overhead. There are similar problems in physics: objects need to know about other objects in order to interact (usually collide) with them.Graphics, sound, AI, I/O, logic should be able to all be seperated if done properly. Running everything in only 1-2 threads is just retarded.
Yes, to the former.
The problem with the later...is that when Intel doesn't have any competition, we consumers get underwhelming generational performance increases.
AMD still makes processors for something other than garbage laptops? News to me. I've been AMD free for like 15 years now.
Please tell me they aren't using liquid nitrogen to achieve this![]()
This 5ghz cpu might run at stock voltage like other FX cpus. If it does then it might overclock to 6ghz with ease. Have to see.![]()
Zarathustra[H];1039792579 said:Whatever.
If it's the same arch as the FX-8350, even at 5Ghz, it will be beaten by a stock i7-3770 in per core performance.
they would need to bump the clock to ~6.5Ghz in order to beat the turbo clock of 3.9Ghz on the 3770 in core for core performance.
By all means AMD, please release higher clocked models, but giving them a racy name like centurion when they aren't even coming close to measuring up to the competition just makes you look silly.
The trick is where you want to go on what numbers on what applications , there already benchmarks which show that AMD beat or get near it. If you running applications on top of eachother like fraps and certain games guess what...
And if you want to fool people start the 4 core vs 8 cores , and you would have to disable HT , goodluck with that one...
but then again with the new HD intel graphics im not sure how well the a8/a10 stacks up anymore, they seem to make for ok cheap laptops that can play some games, far from a gaming laptop, but so is the cost
I've built a few a8 systems for family who want to surf, check email, have a small PC, and play bejeweled type games and other minimal demand type games that need something a little better than cheesy integrated graphics
"AMD is planning on making a Super-FX Chip"
I can't wait to play Star Fox!!!!!!!!
require <> use if available, its called scaling
I could see this price as worth it if it came with 6 or 8 pd modules....12-16 cores @ $800 @ 5ghz would be awesome.
I'm placing my bet now. Even at 5GHZ, it still won't beat the IPC or perf/watt of a now 2 year old Sandy Bridge 2600k running stock with turbo on.
