I mean, they hit their 4Ghz with bullshit voltages so 4Ghz single core turbo does not exactly translate into safe 4Ghz all core OC.
It's a nice little dual socket system though, i must say.
Which is funny since that site used to be bashed for being anti AMD, now it's anti Intel according to them.
7900X with Non-AVX loads get full 10 core boosted to 4.0Ghz, FYI.You dont get a all core boost on Intel as well. You get 1 or 2 cores at the highest speed. Who really cares what voltage they use to get there, they have to warranty it so I figure they know it will last. You take that 7900x to all core at 4.7 and your in to a meltdown situation unless you have a extreme cooling solution. Even 4.6 is difficult and is just a fact of having lots of cores at high speeds and as the core count goes up the speed disparity starts to disappear between Intel and AMD.
If AMD can make the 12/16 cores Ryzen boosted to 4.0Ghz with at least 4 cores then I'll be returning my 7900X soon.
some of the talk is that AMDs design seems to have a very stable wafer production as far as performance. So likely the higher core counts will just be virtually multiples of the lower and behave the same. Thermals didn't seem to be the limiting factor so much as a virtual wall limit they hit for clocks.4.0Ghz is not the max speed of the 7900X and in theory Threadripper can hit 4.0Ghz on all cores but I am not sure if the thermals will allow that, plus the more cores you have the more likely you are to have weak ones. We should know soon at least on threadripper how hard it can be pushed.
What is your infatuation with wattage/TDP/power? He talks of clocks and thermals (which I have already stated the process limits the clocks not the thermals) and you speak only of wattage as if it correlates.![]()
8 RyZen cores pull 260W at 4GHz, double the cores implies double that, i.e. or 518 Watt.
16-core --> ~500W
12-core --> ~390W
You take Ryzen to 4.3Ghz all core without a meltdown, will you? It is the same 200Mhz above single core turbo of 1800X as 4.7 is above 4.5 single core turbo of 7900X.You dont get a all core boost on Intel as well. You get 1 or 2 cores at the highest speed. Who really cares what voltage they use to get there, they have to warranty it so I figure they know it will last. You take that 7900x to all core at 4.7 and your in to a meltdown situation unless you have a extreme cooling solution. Even 4.6 is difficult and is just a fact of having lots of cores at high speeds and as the core count goes up the speed disparity starts to disappear between Intel and AMD.
I cooled over 300W with a crappy 120MM AIO on my 8350. See I am not a moron nor do I whine when things don't go my way. I see an issue I find a way around it. I created an air-conditioned case and laugh at all the self-proclaimed geniuses that act like there is absolutely no way to handle the Watts. How do you feel about Intels absolute nuclear power usage in their >8 cores? So AMD pulls a hypothetical 500W with a 16core, what the hell will Intels 14core pull, 16core pull, 18core pull? Just curious why I haven't seen you in the news threads covering Intels absolute crap TIM and astronomical power and temps with only the 10core.How do you think will be thermals of that hypothetic 500W chip he is predicting (16 Zen cores @4GHz) and how you/him plan to cool that nuclear unit? With a continuous supply of LN2?
LOL and I mean Loud. You said absolutely nothing. a few questions:I already answered the FUD about TIM in two or three ocassions. It is not how if I would be checking each new thread to correct the FUD was corrected before. 14--16 core Intel chips will continue being more efficient than Zen-based chips on non AVX512 workloads, as it has been demonstrated in multiple occasions. Of course, when using AVX512 units (lacking on Zen core) the power consumption will skyrocket just as performance does.
FYI Intel is selling up to 28-core Xeons with AVX512 units and power is well under control. In fact customers are very happy with the huge performance that bring the new 512bit units.
Bud, can you share how you created the AC case.I cooled over 300W with a crappy 120MM AIO on my 8350. See I am not a moron nor do I whine when things don't go my way. I see an issue I find a way around it. I created an air-conditioned case and laugh at all the self-proclaimed geniuses that act like there is absolutely no way to handle the Watts. How do you feel about Intels absolute nuclear power usage in their >8 cores? So AMD pulls a hypothetical 500W with a 16core, what the hell will Intels 14core pull, 16core pull, 18core pull? Just curious why I haven't seen you in the news threads covering Intels absolute crap TIM and astronomical power and temps with only the 10core.
The short version is it is a case that holds both my and my wife's computers. Cant see either nor hear any fans within the case so 100% fans are no bother although the Delta MegaFast fan I have to run on 5V instead of 12V because it is loud at 12V. Anyway I use a window unit air-conditioner in the bottom. There are holes on both sides that allow air in thru the AC (the part outside the window). During winter I exhaust the heat into the room, summer thru a hole in the floor leading under the house. The cooling part blows thru the rear and pulls the warmer thru the front to be cooled. I run it at 75F (mobo shows between 28-30C) so it only cools in intervals so not on much when idle and during gaming every 3-5 min or so (not sure at the moment could be more/longer intervals). When benching crank it to max with mobo showing 17-20C. Best part is NO DUST EVER. And as you can guess I am one of those that said they don't care about Watts in the video card forum section. lol.Bud, can you share how you created the AC case.
any pics?The short version is it is a case that holds both my and my wife's computers. Cant see either nor hear any fans within the case so 100% fans are no bother although the Delta MegaFast fan I have to run on 5V instead of 12V because it is loud at 12V. Anyway I use a window unit air-conditioner in the bottom. There are holes on both sides that allow air in thru the AC (the part outside the window). During winter I exhaust the heat into the room, summer thru a hole in the floor leading under the house. The cooling part blows thru the rear and pulls the warmer thru the front to be cooled. I run it at 75F (mobo shows between 28-30C) so it only cools in intervals so not on much when idle and during gaming every 3-5 min or so (not sure at the moment could be more/longer intervals). When benching crank it to max with mobo showing 17-20C. Best part is NO DUST EVER. And as you can guess I am one of those that said they don't care about Watts in the video card forum section. lol.
not really much to look at, never finished (as in stained/sanded) it. It is fairly large though about 28x40 foot print and about 4 ft tall.any pics?
