From what I heard all of the reviews of the 6850 are with the higher shader count.
The reviewer over at Hardware Canucks says his were 960.
Apparently a small number of the AMD Radeon HD 6850 press samples shipped from AIB partners have a higher-than-expected number of stream processors enabled.
This is because some AIBs used early engineering ASICs intended for board validation on their press samples. The use of these ASICs results in the incorrect number of stream processors. If you have an HD 6850 board sample from an AIB, please test using a utility such as GPU-z to determine the number of active stream processors. If that number is greater than 960, please contact us and we will work to have your board replaced with a production-level sample.
All boards available in the market, as well as AMD-supplied media samples, have production-level GPUs with the correct 960 stream processors.
That's a rather desperate ploy to use.![]()
This is not a ploy by AMD, rather a mistake some board partners have made. All media samples sent out by AMD for the launch were correct.
If you're an optimist, you can hope that the early batches have unlockable ones in the mix.Dang I wanted more shaders on my 6850 that is coming monday.
A reviewer shouldn't have to babysit hardware manufacturers. Of course, it seems that they have to, but it's the hardware manufacturer that is supposed to be honest.completely agree but then the problem lies on the reviewers not doing their jobs and checking the hardware they receive before doing the review..
Did you guys read what Brent wrote?
Why are people still speculating as whether this is a "ploy."
^ they didn't do it on purpose, its the motivation that is the important factor, and as far as i've seen there was no ill intent, accidents happen, glad it was caught and made public, AMD stood up and admitted the issue, so its not like this is a conspiracy
shoot, i'd be thrilled if i bought a retail card that had more shaders enabled on it than was supposed to be
If this was an accident, I'd be a little worried that their quality control is a little lacking. "Oh you mean the 6850 we were testing/developing with isn't the same as the one we're using for production?" Yikes.
Who's buying 6850s anyway? Yawn.
I bought one it is roughly equal to the gtx 460 1gb in performance and price. I needed a new video card so might was well get the newest (also my rig is amd anyways so might as well go with something to compliment it).
