amd or intel for me I need help
vincer20
ok here is the deal im on a 2,000 doller budget i want a mobo cpu combo for a non overclocker that will do me well. i play games like eq2 and would like to play crysis dosent have to be maxxed.i want a solid stable system. and needs to last atleast 2 years.
video card will be 3870x2 or one of nvidiasgamer cards
2,000 is for every thing lcd,computer,desk and so on. thx for any help
where you live might also help, because if you live near a fry's brick and mortar you can get exceptional cpu/board combos often for the price of the chip itself online.
If you get an 8800GT or higher you're better off getting an Intel that gets 3.0GHz min otherwise the gfx card wont be driven to its max.
If clocking the card a lot you will want an even faster CPU.
I found that an A64x2 at 2.8GHz is fast enough to drive an 8800GT at only 80% of its stock GPU speed.
Clocking the card any faster gave no extra performance so I changed to an E8400 and got a huge jump in performance especially after clocking the card to 120% of stock as well :)
Since you're going with an ATI card go with AMD. Make sure that your mobo can support the FSB of your processor because that is what AMD is known for these days.
Well this AMD build gives you some room to move if you have to, and it leaves some leftover for the desk & a set of speakers or headphones of your choice:
AMD Phenom 9600 2.3GHz. Quad-Core CPU
Biostar TA770 A2+ Motherboard
4GB (2 * 2GB) Adata DDR2-800 Memory [$20 MIR]
Diamond Radeon 3870 X2 1GB Video Card
Seagate 500GB 7200RPM 32MB Cache SATA-II Hard Drive
Samsung 20X DVD+-R(W) SATA Burner
Lian-Li PC-61 Case
hec Zephyr 750W Power Supply [$5 MIR]
HannsG 21.6" Widescreen LCD Monitor (5ms rate, HDMI support)
Microsoft Black Keyboard
Microsoft USB 4 Button Mouse
Total After shipping: $1,477 all @ Newegg
I wouldn't go with AMD. I'd get a quad core Intel on an Intel chipset and use the 3870 and be done with it. That will last you two years easily.
Google something like quad core versus duel core test results. I'm a fellow gamer who is going to do a build but am not an OC'er. Dual core smokes the quad in games b/c the games don't utilize anything more than the 2 cores. I'm sure someone will disagree but just google it and read for yourself.
Essentialy you end up with a 3.0 versus a 2.4 regardless of the fact the 2.4 has 2 more cores.
Also go Nvidia on your card. ATI has fallen behind.
You are right for nearly all games out but a few do use all 4 cores and one game Supreme Commander actually needs them or it becomes a chugfest if there are too many objects in game and you want to use high res.
http://enthusiast.hardocp.com/article.html?art=MTMwNiwzLCxoZW50aHVzaWFzdA==
I also agree that for gaming a higher clocked Dual Core is best for now unless Supreme Commander is important to you.
The E8xxx series have 6MB cache, clock like mad and produce less heat, an all round win for most games :)
I had the same dilemma and got an E8400, couldnt be happier, what an awesome chip!
I'll get an even faster quad when they are more useful.
the Hans-G has gotten good write ups, and it is quite cheap compared to other offerings. The HDMI support is great too for hooking up your xbox 360 / ps3
Right now Intel is the way to go unless you already have a AM2 or AM2+ motherboard.
Haha. That IS pretty funny. I guess thats what you get for making a brand-specific forum name... eventually it just isn't accurate.
But yeah, for your budget, and as primarily a gamer, you will want to go with an Intel E8400 like others have said its the new flavor of the month, and for good reason.
